  • Emil Christiansen 66 posts 148 karma points
    Oct 02, 2015 @ 11:49
    Emil Christiansen
    Problems with routing and the Developer section - 401 Authorization has been denied for this request
    We are having problems accessing the developer section in Umbraco.
    We are running on a Umbraco 7.3 and get a 401 error:
    "{"Message":"Authorization has been denied for this request."}"
    The following requests throws a 401 (From Fiddler):
    • /custom-api/ExamineManagementApi/GetIndexerDetails
    • /custom-api/ExamineManagementApi/GetSearcherDetails
    • /custom-api/XmlDataIntegrity/CheckContentXmlTable
    • /custom-api/XmlDataIntegrity/CheckMediaXmlTable
    • /custom-api/XmlDataIntegrity/CheckMembersXmlTable
    When we try to access the developer section - we end up on the Umbraco login-screen. The problem only occurs on the developer section.
    In the 'OnApplicationStarting' eventhandler we have the following route registrations:
            RouteTable.Routes.MapHttpRoute("custom-api-ApiWithAction", "custom-api/{controller}/{action}/{id}", new { id = RouteParameter.Optional });
            RouteTable.Routes.MapHttpRoute("custom-api-ApiWithId", "custom-api/{controller}/{id}", new { id = RouteParameter.Optional });
            RouteTable.Routes.MapHttpRoute("custom-api-ApiGet", "custom-api/{controller}", new { action = "Get" }, new { httpMethod = new HttpMethodConstraint("GET") });
            RouteTable.Routes.MapHttpRoute("custom-api-ApiPost", "custom-api/{controller}", new { action = "Post" }, new { httpMethod = new HttpMethodConstraint("POST") });
            RouteTable.Routes.MapHttpRoute("custom-api-ApiPut", "custom-api/{controller}", new { action = "Put" }, new { httpMethod = new HttpMethodConstraint("PUT") });
            RouteTable.Routes.MapHttpRoute("custom-api-ApiDelete", "custom-api/{controller}", new { action = "Delete" }, new { httpMethod = new HttpMethodConstraint("DELETE") });
    Commenting out those lines fixes the problem - but then we cannot use our custom WebApi on the website.
    Does any of you have any ideas what is going on and how to fix the problem?
    Thanks!
  • Comment author was deleted
    Oct 02, 2015 @ 12:22
    Your custom routes needs to live in /umbraco/backoffice/... then the auth error will go away
    Oct 02, 2015 @ 12:24
    So update to
    RouteTable.Routes.MapHttpRoute("custom-api-ApiWithAction", "umbraco/backoffice/custom-api/{controller}/{action}/{id}", new { id = RouteParameter.Optional });
    Oct 02, 2015 @ 12:37
    Emil Christiansen
    That fixed the problem... thanks!
    If i may ask - what are the explanation behind the "umbraco/backoffice" prefix?
    It seems a bit strange... does it make any sense when we are talking about some custom routes which have nothing to do with the backoffice :) ?
    Oct 02, 2015 @ 12:39
    If I remember correct it's because of member and user authentication not being mixed up
    Oct 02, 2015 @ 12:42
    Emil Christiansen
    Ok, thanks Tim.
    The most important thing is that it is working now...
    It really doesn't matter how the routes are defined... but still think it is a bit strange :)
    Have a great weekend.
    Oct 02, 2015 @ 12:49
    No prob glad it's solved :)
  • Carole Logan 17 posts 118 karma points MVP 9x c-trib
    Jan 13, 2016 @ 15:50
    Carole Logan
    I am also having this issue. I have 2 custom routes that arebeing used when fetching examine data. When I comment out both of these, examine works. Is there a fix for this that doesn't involve changing the route URL to include '/umbraco/backoffice/'?
    Thanks, Carole
  • Ian 178 posts 752 karma points
    Jan 13, 2016 @ 16:52
    Ian
    Hi, some of the documentation about routes in umbraco is a bit confusing. This is what I have found, confirmed by looking at routing in the Umbraco source code.
    The /umbraco/backoffice prefix must be used if you want to provide MVC routes which require back office users to be authenticated rather than front end members. This might be used if you want to use the Legacy iFrame section in umbraco, or load something up in a popup for any reason. These routes must be registered manually as Umbraco does not do any auto routing for this situation.
    For WebApi routes however your controller would normally inherit from one of the documented umbraco controller base classes. You would not register your own routes and would instead rely on Umbraco auto routing to do the job.
