Unpublish Content selected through Multi-Node Picker
My home page has a Multi-Node selector for a carousel, the carousel items are created as content items and selected on the homepage.
I have set each carousel item to 'Unpublish' on a certain date to remove it from the carousel on the page. When I look at the item in Umbraco it is shown as unpublished but the item will still appear in the carousel and can still be selected regardless of being published or not.
What should I do to remove a content item from the site at a specified date and time?
I have set each carousel item to 'Unpublish' on a certain date to remove it from the carousel on the page. When I look at the item in Umbraco it is shown as unpublished but the item will still appear in the carousel and can still be selected regardless of being published or not. What should I do to remove a content item from the site at a specified date and time?
Hi Ginger, if you post the code you are trying I'll give it ago need to know your parameter values to relate.
