We are using SQL CE on small Umbraco 7.2.6 site. The problem is that site is unbelievable slow sometimes. Can it be SQL CE problem ?
Alex
You're most likely suffering from the bug in 7.2.6 that will indeed make you're site very slow at . Make sure to upgrade to 7.2.8.
Thanks, Sebastiaan
Also we have a problem that all changes making from admin are displayed on the site only after republish all site.
Is it the same problem ?
Maybe.. the problem with 7.2.6 is that it can't read from the cache file properly, possibly sending it into a loop of recycles of the app pool. So if the app recycles before it can update the cache then yeah you'd need to republish.
We will try to upgrade the site and write about results.
Upload image
Using SQL CE with Umbraco 7.2.6 performance
Alex
Thanks, Sebastiaan
