  • Eric Schwantler 1 post 71 karma points
    Oct 08, 2015 @ 11:16
    Eric Schwantler
    Problem with SQL Backup
    I did a clean install of Umbraco v7 using WebMatrix and selected SQL Server and then installed SQL Backup package and get following error, any ideas?
    Could not load control: '/UserControls/SQLBackUp/SQLBackUp.ascx'. Error message: System.Web.HttpException (0x80004005): The file '/UserControls/SQLBackUp/SQLBackUp.ascx' does not exist. at System.Web.UI.Util.CheckVirtualFileExists(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at Umbraco.Web.UI.Umbraco.Dashboard.UserControlProxy.OnInit(EventArgs e)
    Oct 08, 2015 @ 11:20
    Dennis Aaen
    Hi Eric and welcome to our :-)
    Try to see this similar topic https://our.umbraco.org/projects/developer-tools/sql-backup/bug-reports-and-issues/70688-install-problem
    Hope this helps,
    /Dennis
