Now to my second question "front-end server tries to insert row in umbracoCacheInstruction".
I have 3 servers (Master, Slave1, Slave2). When I Publish a node on Master a instruction gets inserted to umbracoCacheInstruction. Both Slaves will then try to read the instructions and durning that process a batchmessage gets added to the httpcontext and then read by flushBatch(). This causes the slaves to also write the instructions they read to the database. Conclusion: 3 instructions will be written to umbracoCacheInstruction.
Here is the stack trace of the Slave process when a Master just added a instruction:
ProcessRequest event:
umbraco.dll!Umbraco.Web.BatchedDatabaseServerMessenger.BatchMessage(System.Collections.Generic.IEnumerable<Umbraco.Core.Sync.IServerAddress> servers, umbraco.interfaces.ICacheRefresher refresher, Umbraco.Core.Sync.MessageType messageType, System.Collections.Generic.IEnumerable<object> ids, System.Type idType, string json) Line 133 C#
umbraco.dll!Umbraco.Web.BatchedDatabaseServerMessenger.DeliverRemote(System.Collections.Generic.IEnumerable<Umbraco.Core.Sync.IServerAddress> servers, umbraco.interfaces.ICacheRefresher refresher, Umbraco.Core.Sync.MessageType messageType, System.Collections.Generic.IEnumerable<object> ids, string json) Line 77 C#
Umbraco.Core.dll!Umbraco.Core.Sync.ServerMessengerBase.Deliver(System.Collections.Generic.IEnumerable<Umbraco.Core.Sync.IServerAddress> servers, umbraco.interfaces.ICacheRefresher refresher, Umbraco.Core.Sync.MessageType messageType, System.Collections.Generic.IEnumerable<object> ids, string json) Line 330 C#
Umbraco.Core.dll!Umbraco.Core.Sync.ServerMessengerBase.PerformRefreshAll(System.Collections.Generic.IEnumerable<Umbraco.Core.Sync.IServerAddress> servers, umbraco.interfaces.ICacheRefresher refresher) Line 142 C#
umbraco.dll!Umbraco.Web.Cache.DistributedCache.RefreshAll(System.Guid factoryGuid, bool allServers) Line 208 C#
umbraco.dll!Umbraco.Web.Cache.DistributedCacheExtensions.ClearAllMacroCacheOnCurrentServer(Umbraco.Web.Cache.DistributedCache dc) Line 266 C#
umbraco.dll!Umbraco.Web.Cache.PageCacheRefresher.Refresh(int id) Line 64 C#
Umbraco.Core.dll!Umbraco.Core.Sync.DatabaseServerMessenger.RefreshByIds(System.Guid uniqueIdentifier, string jsonIds) Line 449 C#
Umbraco.Core.dll!Umbraco.Core.Sync.DatabaseServerMessenger.NotifyRefreshers(System.Collections.Generic.IEnumerable<Newtonsoft.Json.Linq.JToken> jsonArray) Line 408 C#
Umbraco.Core.dll!Umbraco.Core.Sync.DatabaseServerMessenger.ProcessDatabaseInstructions() Line 255 C#
Umbraco.Core.dll!Umbraco.Core.Sync.DatabaseServerMessenger.Sync() Line 189 C#
umbraco.dll!Umbraco.Web.BatchedDatabaseServerMessenger.UmbracoModule_RouteAttempt(object sender, Umbraco.Web.Routing.RoutableAttemptEventArgs e) Line 54 C#
umbraco.dll!Umbraco.Web.UmbracoModule.OnRouteAttempt(Umbraco.Web.Routing.RoutableAttemptEventArgs args) Line 599 C#
umbraco.dll!Umbraco.Web.UmbracoModule.ProcessRequest(System.Web.HttpContextBase httpContext) Line 117 C#
umbraco.dll!Umbraco.Web.UmbracoModule.Init.AnonymousMethod__13_3(object sender, System.EventArgs e) Line 568 C#
OnEndRequest event:
umbraco.dll!Umbraco.Web.BatchedDatabaseServerMessenger.WriteInstructions(Umbraco.Core.Sync.RefreshInstruction[] instructions) Line 93 C#
umbraco.dll!Umbraco.Web.BatchedDatabaseServerMessenger.FlushBatch() Line 88 C#
umbraco.dll!Umbraco.Web.BatchedDatabaseServerMessenger.UmbracoModule_EndRequest(object sender, System.EventArgs e) Line 66 C#
umbraco.dll!Umbraco.Web.UmbracoModule.OnEndRequest(System.EventArgs args) Line 606 C#
umbraco.dll!Umbraco.Web.UmbracoModule.Init.AnonymousMethod__13_4(object sender, System.EventArgs args) Line 580 C#
It could be another issue, not sure, will need time to investigate. If you could add these details to the issue you've created already that would be great. Then we can have a look at this for the 7.3.1 release. Until then you'll need write access to that table i suppose.
Flexible load balancing with read-only front-end servers
I am trying to setup a load balancing environment where the front-end servers have read-only to the database.
Using the guide on https://github.com/umbraco/UmbracoDocs/blob/master/Getting-Started/Setup/Server-Setup/Load-Balancing/flexible-advanced.md I did:
Current folder structure:
What works:
What does not work:
front-end server tries to delete row in umbracoCacheInstruction
Is it possible to run umbraco front-end servers with read-only to the database ?
Looks like PruneOldInstructions gets called on every database sync, even if the ServerRole is Slave.
https://github.com/umbraco/Umbraco-CMS/blob/d50e49ad37fd5ca7bad2fd6e8fc994f3408ae70c/src/Umbraco.Core/Sync/DatabaseServerMessenger.cs#L190
Only Master should be clearing old instructions ?
Ahhhh good find. Can you log an issue on the tracker and we'll have it fixed for 7.3.1?
Issue created: http://issues.umbraco.org/issue/U4-7283
OnEndRequest event:
I am not sure if this is intentional, but this will prevent Slaves from running with read-only Database Access using the guide "Advanced techniques with Flexible Load Balancing". https://github.com/umbraco/UmbracoDocs/blob/master/Getting-Started/Setup/Server-Setup/Load-Balancing/flexible-advanced.md
I created it as a new issue http://issues.umbraco.org/issue/U4-7285
