I'm trying to configure a Multinode Tree Picker to only show certain folders from a content repository, which contains many different folders for different content elements.
It's been quite a while since I wrote an xpath expression so I might be a bit rusty doing it.
But I also have a feeling that something might be working dirrently under the hood than it used to do in the versions before 7.
So I have this site structure
Sites
Site
Homepage
Page
Page etc.
Content Repository
Folder 1
Subfolder 1
Element
Element
Folder 2
Subfolder 2
Element
Element
Folder 3
Folder 4
Folder 5
Now I only want the content picker to display the contents of folder 1 and 2.
Thank you for the reply - However it does not change much ind the behavior. When I write
$current/ancestor-or-self::Sites/Site//*[self::Folder1Alias or self::Folder2Alias]
It seems to do the same thing - I only see folders from "Folder1Alias"...and it's actually not listing Folder 1 but the children og Folder 1...I'm a bit confused as to why...can't believe how rusty I have become :-/
Configure MNTP using Xpath - Umbraco 7
Hi guys
Sites
My xpath looks like this
In my picker view all I see is the "Subfolder 1" folder...
How do I need to configure the xpath to have both "Subfolder 1" and "Subfolder 2" available?
I hope the above illustration of my site structure makes sense :)
Cheers, Jan
Aha!
Replace the pipe in the predicate with an "or" - the pipe does concatenation which is not what you want in this case ;)
/Chriztian
Hi Chriztian
Cheers, Jan
...and now I remember why I usually use nuPickers instead...
MNTP only lets you choose a parent folder - not the actual doctypes... :-(
So that's why you're only seeing the children of
Folder1Alias- in both cases (|/or) it's either the only or the first node selected, so.../Chriztian
Aaah, ok - Well I better see if I can look into them nuPickers on the next project then :)...
Thanks for helping out Chriztian.
