  • Ronak Panchal 71 posts 230 karma points
    Oct 27, 2015 @ 04:59
    Ronak Panchal
    Need Help on Examine and sitemap.
    I created a solution in vs 2013 with new Empty MVC Project. after that i install Umbraco CMS via nuget package manager. after that install Umbraco 7.and include items needed in visual studio.
    i use following link to make a site map.Click here
    but i can't get the result.
    do the needful.
    Oct 27, 2015 @ 09:46
    Alex Skrypnyk
    Hi Ronak,
    What is the problem? On what step are you stopping?
    Oct 27, 2015 @ 10:11
    Ronak Panchal
    i m not getting the result of macro with all pages its display only one bullet link. and i want result like below.
    List item
    • List item
    • List item
    • List item
      and i m getting result like below
    • List item
    so problem is that i want all the pages in sitemap but using this link i getting only one page where i m
    Oct 27, 2015 @ 10:48
    Alex Skrypnyk
    Code is pretty simple, maybe problem with TemplateId or publishing nodes?
    Can you do republish and debug ?
    Oct 27, 2015 @ 10:56
    Ronak Panchal
    I have done this. thanks a lot for your feeback.
    Oct 27, 2015 @ 10:57
    Alex Skrypnyk
    Did it help ?
