  • nickornotto 403 posts 907 karma points
    Nov 06, 2015 @ 08:17
    nickornotto
    How to use custom model in macro partial?
    I have a macro where I have a contact form.
    Because the contact form uses Contact model I want my macro to be strongly typed.
    How to make the macro to accept custom model?
    This doesn't work:
    @inherits Umbraco.Web.Macros.PartialViewMacroPage<MyWebsite.Models.ContactModel>
    It says PartialViewMacroPage cannot be used with typed arguments
    I'm using a grid and macro is inserted to the page via macro item of the grid
  • Carl Jackson 139 posts 478 karma points
    Nov 06, 2015 @ 17:18
    Carl Jackson
    I don't think a model can be passed into a macro view only macro parameters/
    If you want a strongly typed model in there you would need to call
    @Html.Action("action", "controller")
    In the macro and they work work with a strongly typed model from the returned view.
    Alternatively extend PartialViewMacroPage with your model and then inherit that? as this essentially is already the model of a UmbracoViewPage
    public abstract class PartialViewMacroPage : UmbracoViewPage<PartialViewMacroModel>
    Thanks.
    Carl
    Nov 10, 2015 @ 17:47
    nickornotto
    I think I just use a standard form and macro without the model :(
    Thanks anyway
