Preview mode breaks when using a default controller with a custom Authorize Attribute
My site implements a default controller which is decorated with a custom authorize attribute. I am using this so I can redirect members who are logged in but not authorised to the right place.
// Employ a custom base controller so all pages need authosisation by default.
DefaultRenderMvcControllerResolver.Current.SetDefaultControllerType(typeof(DefaultController));
The problem is, backoffice users get bounced to my 'not-authorised' page when attempting to preview a page. What I need is either a way to 'authorise' backoffice users or some kind of exclusion (e.g. /umbraco) from routing via my default controller.
The latter would be preferable and TBH maybe this should be logged as a bug - no other backoffice functionality is affected, apart from preview.
My abbreviated custom authorize attribute:
public class CustomAuthorize: AuthorizeAttribute
public override void OnAuthorization(AuthorizationContext filterContext)
base.OnAuthorization(filterContext);
if (filterContext.HttpContext.User.Identity.IsAuthenticated == false)
... redirect to login page
return;
if (UmbracoContext.Current.Security.IsAuthenticated())
...this request is ok - how to authorise so it can continue?
// User is authenticated but not authorised to view the requested page.
if (filterContext.Result is HttpUnauthorizedResult)
...redirect to not authorised
Thanks Dave - the problem is though the Authorize routine still returns a Http unauthorised - I can't figure out how to override this and continue on to the initial request as an authorised user.
e.g. in the above code I am using UmbracoContext.Current.Security.IsAuthenticated() to ensure its a request from a backoffice user - just dunno how to handle it from there.
Ideally I need a solution so any /Umbraco requests do not get routed though my default controller at all. Further testing shows there are other backoffice API requests failing so I may need to raise this as a bug on the issue tracker.
Now I understand the process a bit better I am going to attempt to skip the base.OnAuthorization(filterContext); in my custom Authorise attribute when I detect a backoffice user and see if that means I can skip login altogether on preview - that would be ideal for my scenario.
I missed something quite simple here - I simply checked UmbracoContext.Current.Security.IsAuthenticated() before my custom authorize attribute method hit base.OnAuthorization(filterContext);
Therefore authorization is never performed for backoffice users on the front end. This is ideal in my scenario as it is a very simple, flat membership system with no difference in content or access depending on role.
The only gotcha (so far!) is I need to override MembershipHelper.GetCurrentMember to map backoffice users to a dummy account for front-end browsing.
Follow up to this, I am seeing lots of entries like this in the log:
2015-11-17 08:37:39,888 [P3680/D2/T41] INFO Umbraco.Core.Security.UmbracoMembershipProviderBase - Login attempt succeeded for username me@email.com from IP address 127.0.0.1
2015-11-17 08:37:50,913 [P3680/D2/T49] ERROR Umbraco.Core.Security.AuthenticationExtensions - The current identity cannot be converted to Umbraco.Core.Security.UmbracoBackOfficeIdentity
System.InvalidOperationException: Cannot create a Umbraco.Core.Security.UmbracoBackOfficeIdentity from System.Security.Claims.ClaimsIdentity since the required claim http://schemas.xmlsoap.org/ws/2005/05/identity/claims/nameidentifier is missing at Umbraco.Core.Security.UmbracoBackOfficeIdentity.FromClaimsIdentity(ClaimsIdentity identity) at Umbraco.Core.Security.AuthenticationExtensions.GetCurrentIdentity(HttpContextBase http, Boolean authenticateRequestIfNotFound)
This is happening immediately after a MEMBER login is performed. FYI I am overriding the MembershipHelper to provide my own (very simple) Login method:
public bool SiteLogin(string username, string password)
if (base.Login(username, password))
try
// Find the umb member by username and retrieve the isActivated property
var member = GetByUsername(username);
var isActivated = member.GetPropertyValue<bool>("isActivated");
return isActivated;
catch
return false;
// base Login failed
return false;
Thanks Shannon - looks like a fix is due in 7.4 which will be great.
Just so you know though - This error is still being reported when logging in using the OOTB MembershipHelper.Login() - on a non-protected page, with cookies all wiped beforehand. Basically I have ensured its not running through any custom code to perform the member login/authorisation, and its nothing to do with preview either.
Let me know if you want me to create a new issue for this. Hit me up if you need me to share any setup details if you need to repro (Umbraco version 7.3.0 assembly: 1.0.5750.18157).
I'm getting the same, repeated errors as Barry Fogarty in my newly upgraded 7.4.1 site.
This happens whenever a front-end member signs in and also when a backoffice user signs in or, seemingly, edits a page. I have not done any customization or overrides of the membership providers.
Hi Barry,
Maybe you can check if the page is being used in Preview mode :
Dave
UmbracoContext.Current.Security.IsAuthenticated()to ensure its a request from a backoffice user - just dunno how to handle it from there.Ideally I need a solution so any /Umbraco requests do not get routed though my default controller at all. Further testing shows there are other backoffice API requests failing so I may need to raise this as a bug on the issue tracker.
I think this might have been logged on the tracker already if you wanna give searching there a try
Thanks Shannon - I found the issue and added my experience trying the workaround. Unfortunately I didnt have any success with it:
http://issues.umbraco.org/issue/U4-4219
base.OnAuthorization(filterContext);in my custom Authorise attribute when I detect a backoffice user and see if that means I can skip login altogether on preview - that would be ideal for my scenario.Cheers for pointing out the issue!
UmbracoContext.Current.Security.IsAuthenticated()before my custom authorize attribute method hitbase.OnAuthorization(filterContext);Therefore authorization is never performed for backoffice users on the front end. This is ideal in my scenario as it is a very simple, flat membership system with no difference in content or access depending on role.
Strangely I am getting the doc ID appended twice to my preview URL e.g.
/umbraco/preview/?id=10747#?id=10747Not sure why but thought it worth noting. Preview still works fine but seems to be performing a double redirect.
2015-11-17 08:37:50,913 [P3680/D2/T49] ERROR Umbraco.Core.Security.AuthenticationExtensions - The current identity cannot be converted to Umbraco.Core.Security.UmbracoBackOfficeIdentity System.InvalidOperationException: Cannot create a Umbraco.Core.Security.UmbracoBackOfficeIdentity from System.Security.Claims.ClaimsIdentity since the required claim http://schemas.xmlsoap.org/ws/2005/05/identity/claims/nameidentifier is missing at Umbraco.Core.Security.UmbracoBackOfficeIdentity.FromClaimsIdentity(ClaimsIdentity identity) at Umbraco.Core.Security.AuthenticationExtensions.GetCurrentIdentity(HttpContextBase http, Boolean authenticateRequestIfNotFound)
It's because it's trying to auth a back office user based on an IPrincipal from a front-end member.
As i said, this all needs to be properly fixed at the core level, if you try to force this i'm sure you'll end up with strange things happening.
Ok, if you have steps to repro, please create a new issue for it and let me know the link.
Please see http://issues.umbraco.org/issue/U4-4219 fix is due in 7.4.2
