  • Damon 217 posts 288 karma points
    Nov 27, 2015 @ 09:57
    Damon
    Couple of issues with Courier 2.51.2
    I have started using Courier 2.51.2 to deploy updates in Umbraco V7.
    First, we don't always want to deploy content, because it could be test pages. It looks like the content is listed under Documents in Courier. I deselect all, but the content still seems to merge into the other version of the site. Is this supposed to happen?
    Also, is Courier a little flaky when it comes to picking everything up? There normally seems to be some data types it misses out. Are the data types stored in the database? I think there were a few other things it tends to miss out as well.
    Does this happen with other people?
    Thanks a lot!
    Nov 29, 2015 @ 21:06
    Dennis Aaen
    Hi Damon,
    I have just released a new version of Courier few days a ago Courier 2.51.3 where we have fixed these issues http://issues.umbraco.org/issues/COU?q=%23Fixed+Due+in+version%3A+2.51.3+
    You can download the new Courier version here https://our.umbraco.org/projects/umbraco-pro/umbraco-courier-2/
    To Upgrade Download the hotfix file corresponding to your Umbraco version (Courier_2.51.3.hotfix.zip for v7) and make sure to unblock, then XCOPY all files to the corresponding location in your Umbraco instance - overwriting the older files. Note that the sql is not needed if using Umbraco 6 or 7.
    Hope this helps,
    /Dennis
