  • jools 15 posts 79 karma points
    Dec 02, 2015 @ 16:11
    jools
    Showing uBlogsy Posts on Homepage - need help with authors & date
    Apologies I am very new to Umbraco and not much of a dev.
    I would like to get the 3 most recent UBlogsy posts onto the homepage.
    I have managed to display the 3 most recent posts, but having trouble displaying the author and date how I want to.
    Here is my code that I have in a Partial View Macro:
    @using System.Linq
    @using System.Xml.Linq
    @using umbraco.MacroEngines
    @using uBlogsy.Common.Extensions
    @using uBlogsy.Common.Helpers
    @using uBlogsy.BusinessLogic
    // get all posts IEnumerable
                                    .DescendantsOrSelf("uBlogsyPost")
                                    .Items
                                    .Where(x => x.GetProperty("umbracoNaviHide").Value != "1");
    List<DynamicNode> nodes = postList.OrderByDescending(x => x.GetProperty("uBlogsyPostDate").Value)
                    .Take(3)
                    .ToList();
    <div class="uBlogsy_posts_container uBlogsy_bottom_border">
        <ul>
            @foreach (DynamicNode n in nodes)
                <li style="list-style: none;">
                   <a href="@n.Url">
                        <span>@n.GetProperty("uBlogsyContentTitle").Value</span>
                   </a>
                    <br>
                   <span>@n.GetProperty("uBlogsyPostAuthor").Value</span> - <span>@n.GetProperty("uBlogsyPostDate").Value.FormatDateTimeOrdinal("d.MM.yy")</span>
                </li>
        </ul>
    Now the author displays as the node ID but obviously I would like the actual authors name to appear.
    And for the display of the date, it currently shows as 26th.11.2015. I just need to drop the 'th' and just have numbers.
    Again aplologies if this is a simple fix, I've been at it for a while and just cant get these two fixes done
