Having upgraded to 7.3.3 I am encountering the following problem.
Firstly on the Properties tab of any Content Item .. The Document Type field is blank. It is displaying all the correct fields for the Document Type in question, but this field is blank. More importantly, and maybe related is that just under this, the Template chooser dropdown doesn't appear to be working. It lists the correct templates but whenever I select a new one, it doesn't show up the change in the box.
Just putting this up in case anyone else has experienced the same?
thanks tom.
Problem in Content Editor in 7.3.3
Having upgraded to 7.3.3 I am encountering the following problem. Firstly on the Properties tab of any Content Item .. The Document Type field is blank. It is displaying all the correct fields for the Document Type in question, but this field is blank. More importantly, and maybe related is that just under this, the Template chooser dropdown doesn't appear to be working. It lists the correct templates but whenever I select a new one, it doesn't show up the change in the box. Just putting this up in case anyone else has experienced the same? thanks tom.
The dropdown select is same issue as https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/73517-cant-select-template
so no problem there. Though DocType still empty even in IE.
