  • Sharmarke Hujale 103 posts 346 karma points
    Dec 13, 2015 @ 21:12
    Sharmarke Hujale
    Problem: Can't figure out to give facebook and twitter sharing buttons a dynamic url
    Hi Guys,
    I use Facebook and Twitter's sharing/tweet buttons, so that people can share the content on the specific article/project.
    Here's my meta tags in a partial view macro:
    <!--OpenGraph tags-->
    <meta property="og:title" content="@CurrentPage.Name" />
    <meta property="og:type" content="website" />
    <meta property="og:image "content="@CurrentPage.GetPropertyValue("image")" />
    <meta property="og:url" content="http://localhost:52103/@CurrentPage.Url" />
    <meta property="og:description" content="@Umbraco.Truncate(CurrentPage.content, 297, false)" />
    <!--Twitter Cards-->
    <meta name="twitter:url" content="http://localhost:52103/@CurrentPage.Url">
    <meta name="twitter:title" content="@CurrentPage.Name">
    <meta name="twitter:description" content="@Umbraco.Truncate(CurrentPage.content, 297, false)">
    <meta name="twitter:image" content="@CurrentPage.GetPropertyValue("image")">
    Here's my view (ProjectPost):
    Layout = "Master.cshtml";
         <ul style="margin: 2% 0 2% 0;" class="social-sharing">
                    <li>
                        <div class="fb-share-button" data-href="http://localhost:52103/@Model.Content.UrlWithDomain()" data-layout="button_count"></div>
                    </li>
                    <li>
                        <div>
                            <a class="twitter-share-button"
                                 data-size="large">
                                Tweet
                            </a>
                    </li>
                </ul>
    But I'm not sure if I'm doing the correct way - so I would really appreciate it,
    if someone could help me with this,
    and show me a better way of doing it,
    Thanks in advance.
    /Sharmarke
    Dec 13, 2015 @ 21:25
    Dennis Aaen
    Hi Sharmarke,
    The Model.Content.UrlWithDomain() returns a nicely formated URL including its domain https://our.umbraco.org/documentation/Reference/Querying/UmbracoHelper/
    So try the code below.
                    <li>
                        <div class="fb-share-button" data-href="@Model.Content.UrlWithDomain()" data-layout="button_count"></div>
                    </li>
                    <li>
                        <div>
                                 data-size="large">
                                Tweet
                            </a>
                    </li>
                </ul>
    Hope this helps,
    /Dennis
    Dec 13, 2015 @ 21:39
    Sharmarke Hujale
    Hi Dennis,
    Thanks for your reply - I'll test the code,
    and by the way - is there are better way to use this meta tag:
    Should I remove the Url and only use the '@CurrentPage.Url'
    /Sharmarke
    Dec 13, 2015 @ 23:36
    Sharmarke Hujale
    Hi Dennis,
    I got another side problem here...
    All of sudden, when I put the website online - this is what I get on the project page:
     Runtime Error
    Description: An application error occurred on the server. The current           custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
    Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
    <!-- Web.Config Configuration File -->
    <configuration>
    <system.web>
        <customErrors mode="Off"/>
    </system.web>
    </configuration>
    Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
    <configuration>
    <system.web>
        <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
    </system.web>
    </configuration>
    That's really weird... Because other times when I put the website online, I didn't have that problem,
    it just occured moments ago - and it's only the '/projects' page,
    that is like that.
    /Sharmarke
    Dec 14, 2015 @ 12:44
    Dennis Aaen
    Hi Sharmarke,
    When I do websites, i try to do my code so dynamic as possible and not hardcode things, so your website will work if you change the domain.
     <meta property="og:url" content="@Model.Content.UrlWithDomain()" />
    Hope this helps, and make sense.
    /Dennis
    Dec 14, 2015 @ 14:08
    Sharmarke Hujale
    Hi Dennis,
    I did get it to work, so a big thanks for me,
    And it did make sense to me
    /Sharmarke
  • James Jackson-South 489 posts 1747 karma points c-trib
    Dec 14, 2015 @ 03:45
    James Jackson-South
    Hi Sharmarke,
    If you turn off custom errors in the web.config as instructed and show us the resultant error message is we should be able to give you some pointers.
    <configuration>
    <system.web>
    </system.web>
    </configuration>
    Cheers
    James
