  • Mircea Stanciu 1 post 71 karma points
    Jan 04, 2016 @ 13:31
    Mircea Stanciu
    Custom sql tables with petapoco and mvc routing
    I have a large sql database that I've added connection to web.config. In this database I have listed some services, each row having an id, serviceName, serviceDescription, serviceSummary, serviceBilling.
    Using petapoco, as described here https://www.youtube.com/watch?v=0PtzyrEFG7I i managed to create a view were i can display data.
    This is my petapoco model
    [TableName("[datatable].[dbo].[vw_servicii]")]
    [PrimaryKey("Id", autoIncrement = true)]
    public class Service{
       public int Id { get; set; }
        public int serviceName{ get; set; }
        public string serviceDescription{ get; set; }
        public string serviceSummary{ get; set; }
        public string serviceBilling{ get; set; }}
    then there is this controller that getsAll and get by id:
    public class ServiceController
        public static IList<Service> GetAll()
            UmbracoDatabase db = ApplicationContext.Current.DatabaseContext.Database;
            return db.Fetch<Service>("SELECT * FROM [datatable].[dbo].[vw_servicii] WHERE Id = 201000002");
        public static IList<Servicii> GetAllById(int ServiciuConsularId)
            return db.Fetch<Service>("SELECT * FROM [datatable].[dbo].[vw_servicii] WHERE Id= @0 ", Id);
    My view does this foreach grab of data
     @foreach (var serv in ServiceController.GetAll())
        foreach (var serv in ServController.GetAllById(201000001))
        { <p>@serv.serviceName</p>}
    If i go to /viewName i can see the data. But i need to control the rendering of data with the url. Each product (row in database) must have 3 templates: one to display description, one to display summary, and the last to display the billing data. I should end up with an structure like: /serviceName/templatetype/id.
    A real case would be :
    assurance/description/201000001
    ,were the view would display data from the serviceDescription database column querying "where serviceName=assurance and id =201000001", in the description template . For the same id the url assurance/billing/201000001 would render data from serviceBilling database column using billing template.
    I can't figure out how to tie petapoco with custom mvc routing. Can i do this withoud manualy creating nodes in umbraco's admin?
    kind regard, Mircea
