  • Aki 43 posts 214 karma points
    Jan 10, 2016 @ 01:48
    Aki
    Controller routes and Post request from FormPost gives an error
    Hi Im trying to make a Email Verification on my webpage for a newsletter ..
    Im Using a Route Tabel to Make it a Link in a email.
        RouteTable.Routes.MapRoute(
        "Verify/Newsletter/{contentId}/{verificationHash}",
        new
            controller = "Newsletter",
            action = "Verify",
            id = UrlParameter.Optional
    The Surface controller is controling the Partial view for the Newsletter form and a post including the Verifiy Url path
    public ActionResult RenderSubscriptionFormPartialView()
        return PartialView("Partials/Newsletter/SubscriptionForm", new MailinglistSubscriptionModel());
    // GET: Newsletter/Subscribe
    [HttpPost]
    [ValidateAntiForgeryToken]
    public ActionResult Subscribe(MailinglistSubscriptionModel model)
            return RedirectToCurrentUmbracoPage();
     // GET: Newsletter/Verify
    public ActionResult Verify(int contentId, string verificationHash)
        // Verification success
        return Redirect("/");
    The ting is the Subscribe ActionResult breakes when i make the Route in the route tabel
    and the same with Verify ...
    What am i doing wrong ? The error i get is this..
    Stack Trace:
    [InvalidOperationException: Could not find a Surface controller route in the RouteTable for controller name Newsletter]
           Umbraco.Web.Mvc.RenderRouteHandler.HandlePostedValues(RequestContext requestContext, PostedDataProxyInfo postedInfo) +667
           Umbraco.Web.Mvc.RenderRouteHandler.GetHandlerForRoute(RequestContext requestContext, PublishedContentRequest publishedContentRequest) +69
           Umbraco.Web.Mvc.RenderRouteHandler.GetHttpHandler(RequestContext requestContext) +114
           System.Web.Routing.UrlRoutingModule.PostResolveRequestCache(HttpContextBase context) +174
           Umbraco.Web.UmbracoModule.RewriteToUmbracoHandler(HttpContextBase context, PublishedContentRequest pcr) +163
           Umbraco.Web.UmbracoModule.ProcessRequest(HttpContextBase httpContext) +417
           Umbraco.Web.UmbracoModule.<Init>b__8(Object sender, EventArgs e) +80
           System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +200
           System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +70
    A possible solution is to seperate the Controller out in to 2 one for the default action and one for Route.....
  • Nicholas Westby 2054 posts 7104 karma points c-trib
    Jan 10, 2016 @ 05:11
    Nicholas Westby
    I don't see why you are trying to register a route for your surface controller. For one, surface controllers generate a route for you. Secondly, surface controllers use a mechanism other than the URL to perform routing.
    See here for information on the routing that does not require a particular URL: https://github.com/Nicholas-Westby/LearnUmbraco7/blob/ab9da855fb3a31c816117931ac1997afdc47a82b/Chapter%2006%20-%20Surface%2C%20WebAPI%20and%20RenderMVC%20Controllers/02%20-%20Surface%20Controllers.md#special-routing
    You can scroll up that page for information about the default routes Umbraco generates for surface controllers.
    Jan 10, 2016 @ 17:51
    Aki
    The main reason was to bunch together Functions in a controller that made sense to have together .
    The Web site Would be somthing like this..
    Newsletter SubscribeForm - A partial View with a Webform
    Newsletter Subscribe Post - the post to submit data to umbraco and Create a newsletter
    Newsletter Verify - The route from a site that Verifies the Registered email http://URL/Verify/Newsletter/{ID}/{VerificationCode}
    The address in then included in a email send to the User under post ...
    Jan 10, 2016 @ 20:31
    Nicholas Westby
    If you are going to define your own route rather than use the route automatically created by the surface controller, perhaps you should consider a RenderMvcController. See here: http://stackoverflow.com/a/27526619/2052963
    A RenderMvcController is similar to a surface controller, except you need to create your route for your RenderMvcController, which may be appropriate considering you are attempting to create your own route.
