That can happen if your Visual Studio solution has multiple projects, and each project is reference a different version of Umbraco. For example, if you updated your website to use Umbraco 7.3.4, but your class library is still using 7.3.0, a rebuild of the project could drop the binaries for Umbraco 7.3.0 into your bin folder, which would prevent the installer from running.
That's normal, on first run, Umbraco will run it's migration wizard which will make changes to the database and once complete will update the umbracoConfigurationStatus value
After you updated using NuGet did you save your csproj? It sounds like your references may not have been updated and so your Dll's are still 7.3.0, perhaps you could check the path to Umbraco.Core.dll?
Can you use some sort of diff tool (e.g., WinMerge) to compare the DLL's that come with the Umbraco 7.3.4 ZIP file to ensure they are identical to the DLL's in the bin folder of your website?
Also, you'll want to check your logs in ~/App_Data/Logs to see if they offer any clues.
Problem upgrading from Umbraco 7.3.0 to 7.3.4 using Nuget
Dear Umbraco Folk,
I just attempted to upgrade from Umbraco 7.3.0 to 7.3.4 using Nuget and the instructions at
After the upgrade appeared to complete successfully I have encountered the following issues:
(1) When I restarted Umbraco After the Upgrade the Umbraco Installer did not run.
(2) The Nuget Package manager indicates that 7.3.4 is installed but Web.config includes the following line indicating that Umbraco is still at 7.3.0:
Any help understanding what I may have done wrong in the upgrade, or how to overcome this, would be appreciated.
Terry Clancy
ClanceZ
Thanks Nicholas,
Actually my Solution has only one Project, so I am still not sure what is going on.
Thanks anyway
Terry Clancy
Thank you Jeavon,
But actually the Umbraco Installer / Migration Wizard never appeard to run ? That is the issue - not sure:
Terry Clancy
ClanceZ
~/App_Data/Logsto see if they offer any clues.is working on a reply...
