  • Terry Clancy 204 posts 944 karma points
    Jan 15, 2016 @ 07:10
    Terry Clancy
    Bug with ASP.Net Identity for Umbraco: 'IAppBuilder' does not contain a definition for 'UseUmbracoBackAuthentication'
    Hi all,
    I have a bug using "ASP.Net Identity for Umbraco" which I installed on Umbraco 7.3.4 using Nuget with "Install-Package UmbracoIdentity". See https://github.com/Shazwazza/UmbracoIdentity/ for more info.
    After installing this software "Member" Login is working correctly using the supplied "Account.cshtml" page :-)
    However BackOffice login is failing :-(
    As suggested at
    https://github.com/Shazwazza/UmbracoIdentity/wiki/Startup-Configuration
    I am trying to call the following in my Startup Class:
        //Ensure owin is configured for Umbraco back office authentication
        app.UseUmbracoBackAuthentication();
    but that causes the following error:
    C:\Clancy\A_TeraTastic\Dev\TeraTastic05\TeraTastic\Startup.cs(19,17,19,45): error CS1061:
    and no extension method 'UseUmbracoBackAuthentication' accepting a first argument of type 'IAppBuilder' could be found
    (are you missing a using directive or an assembly reference?)
    Any suggestions as to what the problem is or how to solve it would be very much appreciated.
    Terry Clancy
    ClanceZ
  • Alex Lindgren 159 posts 356 karma points
    Jan 15, 2016 @ 22:14
    Alex Lindgren
    Are you also using Umbraco Identity Extensions?
    https://www.nuget.org/packages/UmbracoCms.IdentityExtensions
    Not sure if this addresses your issue, but I think this comment might be relevant:
    https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/73192-73-identity-issues#comment-234717
    Jan 16, 2016 @ 22:12
    Terry Clancy
    Hi all,
    The specific bug I mentioned above was due to a typo in the UmbracoIdentity documentation.
    As detailed at https://github.com/Shazwazza/UmbracoIdentity/issues/32 Shazwazza has fixed that problem at https://github.com/Shazwazza/UmbracoIdentity/wiki/Startup-Configuration by changing
    to read
    app.UseUmbracoBackOfficeCookieAuthentication(ApplicationContext.Current);
    That got me past that issue but as detailed at https://github.com/Shazwazza/UmbracoIdentity/issues/35 I am now struggling with another issue :-)
    Terry Clancy
    ClanceZ
