    Feb 02, 2016 @ 16:54
    Ismail Mayat
    PDFIndexer Examine rebuild index issue
    Using Umbraco 7.3.5 and i have installed Examine PDFIndexer.
    When i create new pdf file items in media section the items get added to the index. However when i goto examine dashboard and rebuild index those documents are lost all i get in the index is folders
    Anyone seen this before?
    Regards
    Ismail
    Feb 04, 2016 @ 10:33
    Ismail Mayat
    Bit more information on this, I downloaded Umbraco source 7.3.5 and then did index rebuild with break points visual studio picks up exception in the UmbracoDataService on line 21:
            public string MapPath(string virtualPath)
            return HostingEnvironment.MapPath(virtualPath);
    MapPath is somehow being passed a blank virualPath when doing full re index and that is causing it to barf.
    Going to debug a bit more to see whats going on.
    Regards
    Ismail
    Feb 04, 2016 @ 11:00
    Ismail Mayat
    101
    Ok so seems to be issue in pdfindexer, there is something being passed through to Mappath where virtualPath is empty, stepping through with the debugger it was empty image. I deleted those and now it all indexes.
    Regards
    Ismail
    Mar 17, 2016 @ 13:26
    Hi Ismail
    Thanks for the pointer.
    It's a bit weird though since I discovered that I had around 9 blank media items (where the media item is created but there is no physical file mapped to it) - But they all existed in the recycle bin? I don't think that it makes sense that trashed files are being indexed too?
    But I emptied the recycle bin and then the indexer started running - But now I have a lot of entries like
    2016-03-17 14:17:10,846 [P3584/D45/T106] ERROR UmbracoExamine.DataServices.UmbracoLogService - Provider=PDFIndexer, NodeId=20172 System.Exception: UmbracoExamine.FileIndexer: Extension '.png' is not supported at this time
    Eventually the indexer just stops saying one should check the log file...feeling a bit lost now...
    Mar 17, 2016 @ 13:29
    Ismail Mayat
    Ignore those errors I did create post about that and pointed Shannon to it.
    https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/74843-pdfindexer-adding-images-and-folders-to-index
    Just check you have content you should
    Regards
    Ismail
    Mar 17, 2016 @ 13:37
    Hmmm
    Nope, index still says it's 0 - After a while where the indexer has been running I get a red warning message in the ui saying "Server error: Contact administrator, see log for full details. Failed to check index processing"
    So I guess it's never finishing?
    When I check the logfile I just see entries like the one posted above :-/.
    Mar 17, 2016 @ 13:40
    Ismail Mayat
    Jan,
    How many media items do you have? Are you pdfs all located in one place / folder? If they are then update the exmaine pdf indexer to only index that folder see if that works?
    Those png / jpg errors are misleading they are not the issue. When i had this issue i stepped through examine code with debugger and found that media items with no file stopped indexing. On my one now it indexes and i still see those png / jpg errors.
    Regards
    Ismail
    Mar 17, 2016 @ 14:01
    Hi Ismail
    There are around 880 items - The PDF files are unfortunately stored wherever the editor has felt for storing them so it's not restricted to just one folder.
    I just discovered that I'm getting a server error in my console log saying POST http://mysite.com/umbraco/BackOffice/Api/ExamineManagementApi/PostCheckRebuildIndex?indexerName=PDFIndexer 500 (Internal Server Error)
    Any clues what that might be? I'm a bit clueless regarding this.
    Mar 17, 2016 @ 14:25
    Hi again
    Ok, still get the above errors and stuff when I try to index - However! I have some files in the index now.
    I used the good old trick...namely bumping the /config/ClientDependency.config version number and then I recycled the app pool and all of the sudden there were files in the index - I actually also deleted the files in /TEMP/ClientDependency/ - But I'm 99% certain that I did not have to do that.
    When I try to rebuild the files remain in the index even though it still acts weird though.
    Thanks for all your efforts Ismail :)
    EDIT: Feel free to buy a box of the best mangos you can find on me - Soon the season is starting, right? :)
    Mar 18, 2016 @ 07:09
    So just for future reference if others people come across this head-scratching issue I can confirm that upgrading to v1.0.2 of the UmbracoExamine.PDF indexer solves the indexing issue Ismail and I experienced whenever there are "blanks".
    Issue details can be found here https://github.com/umbraco/UmbracoExamine.PDF/issues/8
