  • Atoosa Khoda 96 posts 148 karma points
    Feb 03, 2016 @ 23:43
    Atoosa Khoda
    No Fill for Approved Color Picker
    Is there anyway to add a No Fill/No Colour option to Approved colour picker data type? There should be a way to reset the chosen colour?
    This is Umbraco 7.
    Thanks.
    Feb 04, 2016 @ 05:14
    Hi Atoosa
    It's been a very long while since I've had a go with the Approved color picker but I don't think it's currently possible to reset the color unless you make it possible to select the "Default" within the picker.
    But otherwise it might be worth looking at the spectrum color picker package? https://our.umbraco.org/projects/backoffice-extensions/spectrum-colour-picker/ - Seems like resetting is an option with this package.
    Hope this helps.
  • Samira 113 posts 452 karma points
    Feb 04, 2016 @ 05:19
    Samira
    Try this for No Fill for Approved Color Picker
    In developer section -> datatype->Approved color->choose Color Picker
    set value for no fill color (#fafafa) after that click add button and save datatype
    Regards
    Samira
    Feb 04, 2016 @ 05:39
    Atoosa Khoda
    Samira, #fafafa is a colour, it isn't NO Fill.
