  • Scott Leslie 28 posts 143 karma points
    Feb 05, 2016 @ 14:31
    Scott Leslie
    help using back office active directory package
    https://our.umbraco.org/projects/backoffice-extensions/umbraco-back-office-active-directory-aspnet-provider/
    Umbraco v 7.3.7
    Have followed the instructions, however i am getting the problem:
    "Could not load type 'AdAspNetProvider.Provider.ActiveDirectoryMembershipProvider'."
    Have got the dlls in the bin folder as per instructions: Umbraco.IdentityExtensions.dll AdAspNetProvider.dll
    To use this DLL, you must also have AdAspNetProvider.dll (https://adaspnetprovider.codeplex.com) and the Umbraco Extensibility for ASP.Net Identity (https://www.nuget.org/packages/UmbracoCms.IdentityExtensions/) DLL installed. Umbraco v7.3.1 or newer is required.
  • Brian Powell 44 posts 199 karma points c-trib
    Feb 05, 2016 @ 14:35
    Brian Powell
    If you have the DLL in place, what version of NET Framework is installed on your server?
    Feb 05, 2016 @ 15:22
    Scott Leslie
    Got the site to run.
    Changed type="AdAspNetProvider.Provider.ActiveDirectoryMembershipProvider" to type="AdAspNetProvider.ActiveDirectoryMembershipProvider"
