I am completely new to the Models and Surface Controllers. So I have been following a tutorial about creating a contact form that will send an email. I have followed the tutorial to the letter, but I am getting a couple errors.
using System;
using System.Linq;
using System.Net;
using System.Net.Http;
using System.Text;
using System.Web.Http;
using System.Web.Mvc;
using Umbraco.Forms.Mvc.DynamicObjects;
using Umbraco.Web.Mvc;
namespace Umbraco.Logic.Controllers
public class ContactSurfaceController : SurfaceController
[HttpPost]
public ActionResult Contact(ContactModel model)
if (ModelState.IsValid)
var sb = new StringBuilder();
sb.AppendFormat("<p>Name: {0}</p>", model.Name);
sb.AppendFormat("<p>Email: {0}</p>", model.Email);
sb.AppendFormat("<p>Phone: {0}</p>", model.Phone);
sb.AppendFormat("<p>Company: {0}</p>", model.Company);
sb.AppendFormat("<p>{0}</p>", model.Message);
Library.SendMail("[email protected]", "[email protected]", "Contact Form", sb.ToString(), true);
return RedirectToUmbracoPage(model.ThankYou);
return CurrentUmbracoPage();
Error 1: [HttpPost] - The Type or Namespace name 'HttpPost' could not be found.
Error2: Library.SendMail - 'Umbraco.Forms.MVC.DynamicObjects.Lirary' Does not contain a deffinition for 'SendMail'
These problems look like namespace resolution issues; ie the methods you are trying to use are from different libraries, and your code is trying to use the wrong one. Or at least that is my guess :-)
HttpPost attribute, exists in both System.Web.Mvc and System.Web.Http (and you have both namespaces referenced, so there maybe some abiguity - System.Web.Mvc is for Surface Controllers and System.Web.Http is for API controllers) So if you change:
[HttpPost]
to be
[System.Web.Mvc.HttpPost]
it will remove this abiguity (or remove the using statement for System.Web.Http)
Similarly there is a Library class in Umbraco.Forms.MVC.DynamicObjects but I'm guessing it's not responsible for sending mail.
However there is a SendMail function in the old (legacy umbraco.library namespace - most of these have been moved to the Umbraco. Helper class - but not SendMail as far as I can see)...
eg
umbraco.library.SendMail("youremailstuffhere");
(lowercase u and l)
the hard bit in visual studio is typing the old umbraco namespace with the lowercase u, as it always tries to correct this to the uppercase U !! - but you can cut and paste it in to hopefully get your example to work.
Thanks for the Info. That cleared up my understanding of namespaces and such. I also took your advice and found a tutorial using the SMTP Client in System.Net.Mail.
Unfortunately, I am still not emailing. On submission I get a server error.
The resource cannot be found.
Do you have any Insight to this??? could this be an issue with my SMTP configuration in web.config?
Here is the current control.
using System;
using System.Configuration;
using System.Linq;
using System.Net;
using System.Net.Mail;
using System.Text;
using Umbraco.Models;
namespace Umbraco.Controllers
[ChildActionOnly]
public ActionResult ContactForm()
//in case you need it
var currentNode = Umbraco.TypedContent(UmbracoContext.PageId.GetValueOrDefault());
var model = new ContactModel();
return PartialView("ContactForm", model);
public ActionResult ContactForm(ContactModel model)
SmtpClient smtp = new SmtpClient();
MailMessage message = new MailMessage();
message.To.Add(new MailAddress(ConfigurationManager.AppSettings["ContactAddress"]));
message.Sender = new MailAddress(model.Email);
message.Body = sb.ToString();
message.IsBodyHtml = true;
try
smtp.Send(message);
catch (SmtpException)
//log or manage your error here, then...
return RedirectToUmbracoPage(1337); // <-My published error page.
return RedirectToUmbracoPage(1336); // <-My published succes page.
Thanks for the reply again. This was one of many issues I found since your last message. I only had ("Contact") where it should have been ("ContactFrom").
I am no longer getting any error, which is great, but now the email is simply not sending. I get redirected to my error page. I have tired a couple SMTP accounts.
do I need to do more to reference the smtp account settings in the web.config file?
Problems With Surface Cotroller for sending email from form
How do I correct these errors. Thanks in advance.
Hi Sam
to be
eg
(lowercase u and l)
I'd consider though using the c# SMTPClient in System.Net.Mail to send emails though: https://msdn.microsoft.com/en-us/library/system.net.mail.smtpclient(v=vs.110).aspx
regards
Marc
https://wheeler.kiwi.nz/blog/quick-and-easy-umbraco-7-razor-contact-form/ It helped me clean up my controller a little more.
Server Error in '/' Application. The resource cannot be found.
Hi Sam
What is the markup for your form ?
ie are you using:
Can you put a breakpoint in visual studio on you post handling action, and see if it is hit when the for is posted back ?
and if it is hit, step through each line of code until you get the error ?
then you'll get more of a clue if it is the smtp config at fault or the posting back bit...
Marc,
Hi Sam,
It depends on what you are using for a SMTP service
but something like this if you were using sendgrid:
