  • kevin 1 post 21 karma points
    Feb 16, 2016 @ 18:36
    kevin
    How to render partial view in side Macro view
    I want to render @{Html.RenderPartial("MailSection");} inside my PartialViewMacroPage how can I do that I try by writing @{Html.RenderPartial("MailSection");}
    but its not working for me. it gives error like Error loading Partial View script (file: ~/Views/MacroPartials/ParutionsList.cshtml)
    can any one help me in this.?
    Thanks, Kevin.
  • Marc Goodson 2157 posts 14432 karma points MVP 9x c-trib
    Feb 27, 2016 @ 00:59
    Marc Goodson
    Hi Kevin
    In MVC when you use Html.RenderPartial("viewname") the model that is passed to the partial view is the 'current model' of the view you are calling it from.
    Since you are inside a Macro the current model is of type PartialViewMacroPage, so unless your Partial view is also based on this model you will get an error.
    Usually the workaround is to make the partial you want to render, inherit from IPublishedContent eg change the @inherits statement at the top of the partial to be:
    @inherits UmbracoViewPage<IPublishedContent>
    You would then use inside the partial:
    Model.GetPropertyValue("aliasName") rather than Model.Content.GetPropertyValue("aliasName") etc
    with this change made then inside the Macro you can render the partial view by passing the IPublishedContent element of the PartialViewMacroPage class like so:
    @{Html.RenderPartial("MailSection", Model.Content);}
    if that makes sense ?
    regards
    Marc
  • Robert Tunna 2 posts 22 karma points
    Mar 15, 2017 @ 15:23
    Robert Tunna
    Not sure if this helps anyone, but I managed to get a partial to render in macro after lots of trial and error.
    Macro
    @{ Layout = null; } @{ Html.RenderAction("ActionName", "ControllerName"); }
    Controller
    Any controller logic here
    return PartialView("YourPartialName", viewModel);
    Partial View
    @{ Layout = null; }
    Model Logic Here
