Azure Website not initializing Examine Index after scaling
We upgraded one of our websites from 7.3.1 to 7.3.7 last week. This particular website is required to scale out to run at least 2 instances at the weekend. When the site scaled out to 2 instances, for the first time since we upgraded, I noticed that the Examine indexes were not being initialized on the newly provisioned instance. I noticed this due to the thousands of lines in the log files resembling the following:
Could not retrieve media * from Examine index, reverting to looking up media via legacy library.GetMedia method
Search also did not work on the scaled out instance.
The site did not appear to have any obvious performance issues as a result of this but I imagine there must be, not least due to all the logging it was having to do. I resolved this temporarily by logging into the site and ensuring I was on the scaled instance (by repeatedly deleting the ARRAfinnity cookie) and then running the indexing manually on that server, through the Examine Management page in the browser.
I thought I would investigate this further today so I scaled the site up from 1 to 2 instances again. I also reviewed the Umbraco code in DatabaseServerMessenger.cs as this is the class that seems to be responsible for the initialization. This helped me get a basic understanding of the Initialisation code (although I can't quite tell which bit of code kicks off the Examine Indexing). After scaling I again saw the same issue. The new, secondary server was not initializing it's Examine indexes.
Looking in the DistCache and ExamineIndexes folders in the temp directory, I could see that the DistCache structure was correctly setting the Last Sync ID for the new machine. However, the Examine Indexes were remaining empty for the new machine. At this point I should state that I have also changed my Examine config to use the UseTempStorage="LocalOnly" setting rather than "Sync", but I did this in an attempt to resolve this issue, having read about this recommended configuration in another post. So it may be that the LocalOnly setting is the reason for not being able to see any indexes within the Temp directory (as it is only being stored locally on the machine, not in the website share Temp directory).
However, when I manually ran the Examine Indexes again, this did then populate the associated folder in the Temp/ExamineIndexes/{MACHINENAME} folder. So I'm not sure I'm interpreting the "LocalOnly" setting correctly.
I can't tell at the moment whether this change in behaviour is due to losing a configuration value during the upgrade process or if there is a bug in 7.3.7, it would be great if someone could help me verify that?
If I need to provide any more information on my configuration please let me know. Thanks for your help.
LocalOnly means that the indexes will be stored on the webworker machines that the site is running on and not in the central folder, which is definitely what you want in a LB setup.
Note: I'm no LB expert so for your next 12 questions the problem will probably be: dunno. :) I know that when the documentation is followed completely it should work.
Thanks Sebastiaan, I will review the guidance again. I should point out that this was working prior to the recent upgrade, so it seems that either my upgrade process has changed something in the configuration (my mistake), or the new version has introduced/revealed the issue. I'll continue investigating.
Strange, if there are no Examine indexes, Umbraco will start building them when it starts so they should be back as soon as the first page appears from the fresh webserver.
I'm starting to think now that it's nothing to do with scaling - I don't think my site is indexing at all anymore. Is there any common scenario that might cause that to happen? I'll go back and check my config.
Hi Damiaan, I've investigated this further, without a great deal of success though. Another thing I should have pointed out is that if I manually run the indexes through the browser then they run just fine. It also seems to pick up newly published content ok. It's just when the site is on a new server (happens quite a lot in Azure Web Apps) then the index doesn't initialize itself correctly. It happened last night again, so I've had to go in and manually kick off the indexer.
These are the log entries when a new instance is added:
Could permissions be a problem if I'm able to run it just fine manually through the browser? We are using the LocalOnly setting which means it's putting the index in the ASP.Net temporary file location, so presumably that would also rule out permissions as being the cause.
Is the site under heavy load? If not, I would turn switch to debug level. To be sure you are not missing something. My guess is that we are missing some events where it is stated the Examine index can not be created.
Also the "directoryNotFound" exception means that the startup or server sync has had a problem earlier.
PS: Is your appsetting umbracoContentXMLUseLocalTemp set to true?
Yes we are using that setting. I'm not concerned about that "error" in the logs - that is just because it is a new machine/instance and thus the umbraco.config doesn't exist yet. Not sure that should be an error in the logs, but I believe we can ignore that.
I will look to increase the logging level and scale up later today, to see if we get any additional information.
OK, I've increased the logging (DEBUG) and apart from flooding the logs I don't think it provides anything useful. Below are all of the logs that mention "Examine":
*2016-02-24 12:27:39,956 [11] DEBUG Umbraco.Core.CoreBootManager - Executing Umbraco.Web.Search.ExamineEvents in ApplicationInitialized
2016-02-24 12:27:40,591 [11] DEBUG Umbraco.Core.CoreBootManager - Executing Umbraco.Web.Search.ExamineEvents in ApplicationStarting
2016-02-24 12:28:12,043 [11] WARN Umbraco.Web.PublishedCache.XmlPublishedCache.PublishedMediaCache - Could not retrieve media 16684 from Examine index, reverting to looking up media via legacy library.GetMedia method*
There's plenty more lines in the log files but it's hard to know what's relevant.
When you bring a new site online (scale out) it will not be synced - it will not have the umbraco.config xml cache file and will not have any Examine indexes. When this happens, we call this a 'cold boot'. The process is
Check the local \App_Data\TEMP\DistCache[SERVERNAME][AppDomainAppId]-lastsynced.txt file to see what data the site has in it's caches. If this file doesn't exist, it performs a cold boot = rebuilds the xml cache file and Examine indexes
If this file does exist but the number of new instructions in the instructions table exceeds the number MaxProcessingInstructionCount then a cold boot will occur (default is 1000). Otherwise it will read in the un-processed instructions and sync all caches to the last id in the instructions table
So, when you bring a new site online you should get the message indicating that the lastsynced.txt doesn't exist and that a cold boot will occur. You should get logs indicating that the indexes will be rebuilding. You can also force a cold boot by deleting the lastsynced.txt file ... though this should only be done for testing purposes since you definitely don't want to cold boot every time your site restarts.
we're having the same issue, the result is the production website unexpectedly and suddenly empty.
We have only one instance enabled on Azure, and this problem happens sometimes, when Azure decides to change machine, terminating the current web application on the current server, and bringing a new instance on a new machine online.
From the log file, I see that the cold boot is started, but at the end no Examine indexes are created. And in the meanwhile SaveLastSynced(lastId) is executed, without actually having synced. This put the application in an invalid state.
I cannot understand why Examine indexes aren't created..
I attach the log when the application starts on a new machine, and my ExamineSettings.config.
Log:
2016-03-11 22:07:23,624 [P3412/D2/T1] INFO Umbraco.Core.CoreBootManager - Umbraco 7.3.7 application starting on RD000D3A22DBDF
2016-03-11 22:07:23,702 [P3412/D2/T1] INFO Umbraco.Core.PluginManager - Determining hash of code files on disk
2016-03-11 22:07:23,780 [P3412/D2/T1] INFO Umbraco.Core.PluginManager - Hash determined (took 83ms)
2016-03-11 22:07:28,888 [P3412/D2/T1] INFO Umbraco.Core.DatabaseContext - CanConnect = True
2016-03-11 22:07:28,916 [P3412/D2/T1] WARN Umbraco.Core.Sync.DatabaseServerMessenger - No last synced Id found, this generally means this is a new server/install. The server will build its caches and indexes, and then adjust its last synced Id to the latest found in the database and maintain cache updates based on that Id.
2016-03-11 22:07:28,963 [P3412/D2/T1] INFO umbraco.content - Load Xml from file...
2016-03-11 22:07:28,963 [P3412/D2/T1] ERROR umbraco.content - Failed to load Xml from file.
System.IO.DirectoryNotFoundException: Could not find a part of the path 'D:\local\Temporary ASP.NET Files\root\25b6bfe3\4b69c977\UmbracoData\umbraco.config'.
at System.IO._Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITYATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at umbraco.content.LoadXmlFromFile()
2016-03-11 22:07:28,979 [P3412/D2/T1] INFO umbraco.content - Loading content from database...
2016-03-11 22:07:30,588 [P3412/D2/T1] INFO umbraco.content - Loading content from database...
2016-03-11 22:07:31,808 [P3412/D2/T1] INFO Umbraco.Web.Cache.CacheRefresherEventHandler - Initializing Umbraco internal event handlers for cache refreshing
2016-03-11 22:07:31,855 [P3412/D2/T1] INFO Umbraco.Web.Search.ExamineEvents - Initializing Examine and binding to business logic events
2016-03-11 22:07:31,855 [P3412/D2/T1] INFO Umbraco.Web.Search.ExamineEvents - Adding examine event handlers for index providers: 4
2016-03-11 22:07:31,871 [P3412/D2/T1] INFO MyProject.EventHandlers.MyProjectApplicationEventHandler - OnApplicationStarted: add OnGatheringNodeData to ExternalIndexer
If I well understand the Shannon's post, if I stop my Azure web app, then I remove the \App_Data\TEMP\DistCache[SERVERNAME][AppDomainAppId]-lastsynced.txt file, and I start again the web app, xml cache file and Examine indexes should be rebuilt.
But this doesn't happen to my web application.
I see 2 differences between my and your ExamineSettings configuration
You set useTempStorage="LocalOnly". I tried using it, but the result doesn't change
I didn't see any relevant behaviour difference between LocalOnly and Sync either. I'm not sure about the tempStorageDirectory, I haven't seen that before and is not mentioned in the Azure / Load Balancing guidance.
When I get a chance I will try out Shannon's suggestions.
I still have this issue, but I have not tried anything else to fix it. We have monitoring set up to alert us when the search pages stop working and we then log in and manually run the indexes. Not ideal but I can't invest any more time on this at the moment. It only seems to happen once every 2 weeks or so.
We'll probably upgrade to 7.5 (or more likely 7.5.2 ;0)) once that comes out and we're hoping this will just start working again...
We are seeing the same issue as well. Every time Azure migrates the web application to a new server - our Examine indexes are empty and do not rebuild.. We are using a 'staging' deployment slot in our Azure WebApp - not sure if it makes any difference.
I haven't tried the BootManager extension. Has it worked for anyone else?
Does anyone have anything further to report? I note the issue on the tracker, but it seems to be mothballed and I really don't believe this a live issue - otherwise Umbraco Cloud would have a serious problem. Has anyone managed to fix this with a config change, an Umbraco upgrade or a workaround?
I'm planning to try @Giordiano's index rebuilder but as the problem only surfaces when Azure do some overnight maintenance, I'm not sure I'll be able to test it.
Would appreciate any further info if anyone has something to add.
I've sort of resolved this issue, I could have sworn I posted the solution somewhere on the Umbraco forum, but can't find it.
Anyway, in 7.3.x cold boot indexing is botched and will not work, so every time Umbraco needs to do so it will leave you with (almost) empty index folders and an index with 0-10 items inside it. The only way I could solve it without updating to 7.4 was removing the {machineName} from the index location path. Then you need to rebuild the index manually in CMS on the content management node and also on the content delivery node (hopefully you didn't block the /umbraco path permanently). It's also good to set the RebuildOnAppStart = false in your ExamineSettings.config file, so that Umbraco will not try to do a cold boot index rebuild at any time.
This allows the indexes to persist even if Azure decides to switch the underlying machine of your AppService, while it will still allow Umbraco to update the index when changes are made in CMS. However, it has two big drawbacks:
You can't have multiple Content Delivery nodes in Azure as they can't both achieve a lock in one folder,
every time you make many changes at once (e.g. Courier many new content items) you will need to manually rebuild the Examine index both on CM and CD nodes.
Fortunately, updating to 7.4.x fixes the cold boot indexing issue. If anyone is curious, I use a following setup:
staging slot for CD node,
RunAsync = false on each index,
RebuildOnAppStart = true or just removed, it's true by default,
{machineName} in the index location path,
1 CM node and 2 CD nodes.
The Content Delivery nodes have separate folders based on the current machine name, so there's no problem with locking their indexes. Each time I deploy a new version of CMS project, it's deployed to the staging slot, then Umbraco starts rebuilding the index (usually there are many changes). In the meantime a slot-swap command is executed, it awaits till the machine responds with 200 and then swaps the staging slot for production. However, the RunAsync = false setting prevents the staging slot from returning 200 before the indexes are ready. The slot-swap is being retried each time it fails, so when the indexes are ready, the actual swap takes place. And voila a deploy with no downtime is born.
Thanks for taking the time to reply Bartosz. I'm already on v7.4.3 so I don't think your scenario is the same as mine. I will try the runAsync flag though, that definitely sounds promising. Will post back here any findings. #H5YR
We are seeing the same error on 7.4.3, but don't think it's a problem with how the indexes are built, but with the query used to retrieve media items. We're seeing it even on a single local development instance.
If I use the Examine Manager to run a query, it does find the media item in the external index, e.g.
__NodeId:2020
However running a debug instance of Umbraco, and stepping through PublishedMediaCache.GetUmbracoMediaCacheValues, I can see the filter being built looks like this:
+(+null -__Path:-1,-21,*) +__IndexType:media
even though the inline code comment says it should build one like this:
The null is being returned from Examine, but I'm not yet sure whether this is an Examine bug, a Lucene.NET bug, or whether Umbraco is using Examine incorrectly.
I'm trying my own builds of Examine and Lucene.NET to try and find out.
James.
Make sure you follow the load balancing guide to the letter:
https://our.umbraco.org/documentation/Getting-Started/Setup/Server-Setup/load-balancing/
I have had issues with indexing in the past with custom events swallowing exceptions.
Or I forgot to setup write permissions.
Thanks, James.
Is the site under heavy load? If not, I would turn switch to debug level. To be sure you are not missing something. My guess is that we are missing some events where it is stated the Examine index can not be created. Also the "directoryNotFound" exception means that the startup or server sync has had a problem earlier.
Hi Damiaan,
Thanks for your input.
James.
2016-02-24 12:27:43,688 [11] DEBUG UmbracoExamine.DataServices.UmbracoLogService - InternalIndexer indexer initializing, Provider=InternalIndexer, NodeId=-1
2016-02-24 12:27:44,047 [11] DEBUG UmbracoExamine.DataServices.UmbracoLogService - InternalMemberIndexer indexer initializing, Provider=InternalMemberIndexer, NodeId=-1
2016-02-24 12:27:44,125 [11] DEBUG UmbracoExamine.DataServices.UmbracoLogService - ExternalIndexer indexer initializing, Provider=ExternalIndexer, NodeId=-1
2016-02-24 12:27:55,513 [11] DEBUG Umbraco.Core.CoreBootManager - Executing Umbraco.Web.Search.ExamineEvents in ApplicationStarted
2016-02-24 12:27:55,525 [11] INFO Umbraco.Web.Search.ExamineEvents - Initializing Examine and binding to business logic events
2016-02-24 12:27:55,525 [11] INFO Umbraco.Web.Search.ExamineEvents - Adding examine event handlers for index providers: 3
2016-02-24 12:27:55,525 [11] DEBUG Umbraco.Core.CoreBootManager - Complete (took 12ms)
I've just manually run the index just to capture the process in a log file and these are the key first few lines I see -
2016-02-24 12:52:47,851 [11] DEBUG Umbraco.Web.UmbracoModule - Begin request: http://[DOMAIN]/umbraco/BackOffice/Api/ExamineManagementApi/PostRebuildIndex?indexerName=ExternalIndexer. 2016-02-24 12:52:47,913 [11] DEBUG UmbracoExamine.DataServices.UmbracoLogService - Rebuilding index, Provider=ExternalIndexer, NodeId=-1 2016-02-24 12:52:47,945 [11] DEBUG UmbracoExamine.DataServices.UmbracoLogService - (ExternalIndexer) PerformIndexAll with XPATH: //[(number(@id) > 0 and (@isDoc or @nodeTypeAlias))], Provider=ExternalIndexer, NodeId=-1 2016-02-24 12:52:49,324 [11] DEBUG UmbracoExamine.DataServices.UmbracoLogService - Index deleted for term: __IndexType with value content, Provider=ExternalIndexer, NodeId=-1 2016-02-24 12:52:49,804 [11] DEBUG UmbracoExamine.DataServices.UmbracoLogService - Index created for node 1090, Provider=ExternalIndexer, NodeId=1090 2016-02-24 12:52:49,804 [11] DEBUG UmbracoExamine.DataServices.UmbracoLogService - Index created for node 3106, Provider=ExternalIndexer, NodeId=3106*
Repeat, repeat, repeat (for that last line as it indexes each node)
So none of this shows up when the site first loads, only with a force index.
MaxProcessingInstructionCountthen a cold boot will occur (default is 1000). Otherwise it will read in the un-processed instructions and sync all caches to the last id in the instructions tableSo, when you bring a new site online you should get the message indicating that the lastsynced.txt doesn't exist and that a cold boot will occur. You should get logs indicating that the indexes will be rebuilding. You can also force a cold boot by deleting the lastsynced.txt file ... though this should only be done for testing purposes since you definitely don't want to cold boot every time your site restarts.
Hi, we're having the same issue, the result is the production website unexpectedly and suddenly empty.
I cannot understand why Examine indexes aren't created.. I attach the log when the application starts on a new machine, and my ExamineSettings.config.
2016-03-11 22:07:28,963 [P3412/D2/T1] ERROR umbraco.content - Failed to load Xml from file. System.IO.DirectoryNotFoundException: Could not find a part of the path 'D:\local\Temporary ASP.NET Files\root\25b6bfe3\4b69c977\UmbracoData\umbraco.config'. at System.IO._Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITYATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at umbraco.content.LoadXmlFromFile()
2016-03-11 22:07:33,982 [P3412/D2/T1] INFO Umbraco.Core.CoreBootManager - Umbraco application startup complete (took 11087ms)
2016-03-11 22:07:34,636 [P3412/D2/T13] INFO umbraco.content - Save Xml to file...
2016-03-11 22:07:34,636 [P3412/D2/T6] INFO umbraco.content - Saved Xml to file.
2016-03-11 22:34:41,331 [P3412/D2/T35] INFO Umbraco.Core.Sync.ApplicationUrlHelper - ApplicationUrl: https://MyProject.azurewebsites.net/umbraco (using scheduledTasks/@baseUrl)
Thanks Giordano, your config is slightly different to mine. For reference here's my ExamineSettings.config:
Hi James, thanks for posting your configuration.
If I well understand the Shannon's post, if I stop my Azure web app, then I remove the \App_Data\TEMP\DistCache[SERVERNAME][AppDomainAppId]-lastsynced.txt file, and I start again the web app, xml cache file and Examine indexes should be rebuilt. But this doesn't happen to my web application.
I hope someone could help us.
Thanks, Giordano
Hi Giordano,
James.
Hi, as a workaround, I have extended the WebBootManager class with a custom one, and I have overridden Complete(Action
Do you know yet if that has had the desired effect?
James.
Hi James,
from the logs I can see the custom rebuilding is called, but I don't know what happens next time Azure will switch machine.
thanks,
Giordano
Has anyone managed to resolve this problem? I'm experiencing exact same issue. The custom WebBootManager above unfortunately didn't help at all :(
Hi Bartosz,
James.
Any update on this?
EDIT: I just noticed an umbraco issue has been created for this thread http://issues.umbraco.org/issue/U4-8249
{machineName}from the index location path. Then you need to rebuild the index manually in CMS on the content management node and also on the content delivery node (hopefully you didn't block the /umbraco path permanently). It's also good to set theRebuildOnAppStart = falsein yourExamineSettings.configfile, so that Umbraco will not try to do a cold boot index rebuild at any time.This allows the indexes to persist even if Azure decides to switch the underlying machine of your AppService, while it will still allow Umbraco to update the index when changes are made in CMS. However, it has two big drawbacks:
RunAsync = falseon each index,RebuildOnAppStart = trueor just removed, it's true by default,{machineName}in the index location path,The Content Delivery nodes have separate folders based on the current machine name, so there's no problem with locking their indexes. Each time I deploy a new version of CMS project, it's deployed to the staging slot, then Umbraco starts rebuilding the index (usually there are many changes). In the meantime a slot-swap command is executed, it awaits till the machine responds with 200 and then swaps the staging slot for production. However, the
RunAsync = falsesetting prevents the staging slot from returning 200 before the indexes are ready. The slot-swap is being retried each time it fails, so when the indexes are ready, the actual swap takes place. And voila a deploy with no downtime is born.Thanks for taking the time to reply Bartosz. I'm already on v7.4.3 so I don't think your scenario is the same as mine. I will try the runAsync flag though, that definitely sounds promising. Will post back here any findings. #H5YR
__NodeId:2020However running a debug instance of Umbraco, and stepping through PublishedMediaCache.GetUmbracoMediaCacheValues, I can see the filter being built looks like this:
+(+null -__Path:-1,-21,*) +__IndexType:mediaeven though the inline code comment says it should build one like this:
+(+__NodeId:2020 -__Path:-1,-21,*) +__IndexType:mediaThe null is being returned from Examine, but I'm not yet sure whether this is an Examine bug, a Lucene.NET bug, or whether Umbraco is using Examine incorrectly.
