  • Ashton Alexander 3 posts 73 karma points
    Feb 25, 2016 @ 22:10
    Ashton Alexander
    Need to pass dynamic model, or call controller method in Partial View Macro
    Hi everyone,
    Umbraco 7.3.4
    Here's my Partial View Macro code - description of problem below:
     var newLowestAPR = "1.50%"; //needs to be dynamic
     var usedLowestAPR = "1.75%";
    <ul class="featured-rates">
        <li>
            <h2><span>New Vehicle APR As Low As:</span></h2>
            <h2>@newLowestAPR</h2>
        </li>
        <li>
            <h2><span>Used Vehicle APR As Low As:</span></h2>
            <h2>@usedLowestAPR</h2>
        </li>
    </ul>
    Currently the APRs that are set have hardcoded values. I have the values I need within a backoffice controller that returns a list.
    I'd ideally hit this controller method and pass the list to my view, and update the view with that data. //I've commented the variables above with what is static that should be dynamic.
    My question is, what is the best route to go for getting my data?
    Should I be attempting to access the backoffice controller method? I've read into surface controllers, but haven't had much luck. Even if I could simply read data from my umbraco database table, that would work.
    Any help on this, or point outs in the correct direction would be extremely helpful.
