Umbraco.Core junks my class library projects with web files
This behavior seems to be new to Umbraco 7.4.
I have separate my business logic from my display logic into class library projects in Visual Studio. I added UmbracoCms.Core via NuGet in these projects.
The problem is that the UmbracoCms.Core reference tries to create a complete Umbraco web installation in each of my DLL projects., It creates the AppBrowsers,Config,Umbraco,umbracoclient folders every time I build.
How do I stop this? All I need is access to the Umbraco.Core namespace.
If I do a -WhatIf then NuGet tells me it will install the following packages (and it does, if I leave out the -WhatIf). Any other packages installed that have a dependency on UmbracoCms (not .Core)?
I think my misunderstanding was that I must install all the Umbraco.Core dependencies if I need to use Umbraco.Core in a class library project.
But that is wrong - if I just need Umbraco.Core, I should tell NuGet to ignore dependencies.
I just used ResolveUR to remove all unused referenced and packages in my project.
Are you sure you only installed
UmbracoCms.Core?If I do a
-WhatIfthen NuGet tells me it will install the following packages (and it does, if I leave out the-WhatIf). Any other packages installed that have a dependency onUmbracoCms(not.Core)?I think my misunderstanding was that I must install all the Umbraco.Core dependencies if I need to use Umbraco.Core in a class library project.
I don't know how you're installing
Umbraco.Corebut as per the output above:This will not install dependencies and there's no need to tell NuGet to ignore them. Maybe I'm missing something?
I am getting different behavior. I believe this is the default NuGet setting:
I used the "quick install package" menu to install Umbraco.Core:
This is what it did:
I then discarded my changed and ran " Install-Package UmbracoCms.Core"
This is the console output:
So as far as I can tell, installing UmbracoCms.Core will install all the dependencies unless you tell NuGet not to.
