  • louisjrdev 107 posts 344 karma points c-trib
    Feb 26, 2019 @ 16:35
    louisjrdev
    Error Running fresh V8 Install
    Hi all,
    Got an odd issue setting up a new V8 site,
    I setup a new ASP.Net Web Application (Empty) using .Net version 4.7.2 and installed the nuget package, then when i build and run the site through IIS im getting the following error:
    Any help is much appreciated
  • Jo Kendal 32 posts 194 karma points
    Feb 26, 2019 @ 16:38
    Jo Kendal
    Have you tried adding a reference to that dll, i.e. System.IO.Compression
    Feb 26, 2019 @ 16:41
    louisjrdev
    My project already has a reference to 4.2.0.0 although it is showing another available version to reference which is 4.1.2.0
    Feb 26, 2019 @ 16:48
    Jo Kendal
    I have a fresh install in front of me with no reference to that namespace at all. What are you using it for? Where is it being referenced?
    Feb 26, 2019 @ 16:51
    louisjrdev
    im not using it at all, ive literally not even set up a db yet, it was in as dependent assembly in the web.config
    <dependentAssembly>
        <assemblyIdentity name="System.IO.Compression" publicKeyToken="b77a5c561934e089" culture="neutral"/>
        <bindingRedirect oldVersion="0.0.0.0-4.2.0.0" newVersion="4.2.0.0"/>
      </dependentAssembly>
    i have also tried deleting those lines in web.config but then it goes on to do the same for System.IO
    Feb 26, 2019 @ 16:53
    Jo Kendal
    So - on my fresh install all I have is:
      <runtime>
        <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
          <dependentAssembly>
            <assemblyIdentity name="Microsoft.Owin" publicKeyToken="31bf3856ad364e35" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-4.0.1.0" newVersion="4.0.1.0" />
          <dependentAssembly>
            <assemblyIdentity name="Microsoft.Owin.Security" publicKeyToken="31bf3856ad364e35" culture="neutral" />
          <dependentAssembly>
            <assemblyIdentity name="Microsoft.Owin.Security.Cookies" publicKeyToken="31bf3856ad364e35" culture="neutral" />
          <dependentAssembly>
            <assemblyIdentity name="Microsoft.Owin.Security.OAuth" publicKeyToken="31bf3856ad364e35" culture="neutral" />
          <dependentAssembly>
            <assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-12.0.0.0" newVersion="12.0.0.0" />
          <dependentAssembly>
            <assemblyIdentity name="System.Collections.Immutable" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-1.2.3.0" newVersion="1.2.3.0" />
          <dependentAssembly>
            <assemblyIdentity name="System.Web.Http" publicKeyToken="31bf3856ad364e35" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-5.2.7.0" newVersion="5.2.7.0" />
          <dependentAssembly>
            <assemblyIdentity name="System.Web.Mvc" publicKeyToken="31bf3856ad364e35" culture="neutral" />
          <dependentAssembly>
            <assemblyIdentity name="System.ValueTuple" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-4.0.3.0" newVersion="4.0.3.0" />
          <dependentAssembly>
            <assemblyIdentity name="System.Net.Http.Formatting" publicKeyToken="31bf3856ad364e35" />
        </assemblyBinding>
      </runtime>
    Feb 26, 2019 @ 16:56
    louisjrdev
    Thanks Jo this fixed it, interesting how my install was different though, tried installing a fresh project twice with the same result.
    Feb 26, 2019 @ 16:57
    Jo Kendal
    No worries - no idea why my badge states [notactivated]!
