  • Jesper Ordrup 1019 posts 1528 karma points MVP
    Feb 27, 2019 @ 23:51
    Jesper Ordrup
    Installing Umbraco 8 using nuget?
    Hi there,
    Using Visual Studio 2017
    Im trying to install Umbraco V8 using nuget without much luck. Ive tried using Web application project and just website (not application).
    After doing install-package umbracoCms, I run the project and the message goes:
    Could not load file or assembly 'Microsoft.CodeDom.Providers.DotNetCompilerPlatform, Version=2.0.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    Installing this and rerunning project gives me:
    Could not load type 'Umbraco.Web.UmbracoApplication'.
    Visual Code
    Using the god ole unzip works fine but has anyone succeded in installing V8 using nuget here?
    best
    Jesper
    Feb 28, 2019 @ 00:11
    Alex Skrypnyk
    101
    Hi Jesper
    Please, check your Visual Studio version, it should be at least 2017 version 15.9.6+, check requirements:
    Local Development
    Microsoft Windows 7 SP1
    Visual Studio Code with the IISExpress extension or Microsoft Visual Studio 2017 version 15.9.6+
    ASP.NET 4.7.2
    https://our.umbraco.com/documentation/Getting-Started/Setup/Requirements/
    Alex
    Feb 28, 2019 @ 00:46
    Jesper Ordrup
    Thanks Alex :-)
    (damn ....)
  • Dave 8 posts 80 karma points
    Feb 28, 2019 @ 10:28
    Dave
    Same issue here, however I have just updated to 15.9.7
    Installed using
    Install-Package Microsoft.CodeDom.Providers.DotNetCompilerPlatform
    However...
  • Thomas Heaney 8 posts 29 karma points
    Feb 28, 2019 @ 11:21
    Thomas Heaney
    I had the same problem with DotNetCompiler. According to the NuGet package manager I was using version 2.0.0. Upgrading to 2.0.1 fixed this.
    Feb 28, 2019 @ 11:29
    Dave
    Got it!
    Make sure you are installing it in a project using the correct .net framework, I hadnt updated to the latest version, so tried installing it in a 4.6.2 project (latest I had) and thats why.
    Updated to 4.7.2 and im in.
    Feb 28, 2019 @ 12:29
    Sebastiaan Janssen
    3
    FYI: I've update the v8-specific install guide to mention not to forget the .NET Framework version and the correct VS2017 version.
    https://our.umbraco.com/Documentation/Getting-Started/Setup/Install/install-umbraco-with-nuget
  • RockawayRichie 1 post 21 karma points
    Apr 08, 2020 @ 00:56
    RockawayRichie
    Adding the package worked for me.
    Thanks for the help.
