  • krzakivan 27 posts 93 karma points
    Mar 04, 2019 @ 16:19
    krzakivan
    Problem with targert version
    Im getting this error if I want to run Umbraco v8 on my website:
    Parser Error Message: The 'targetFramework' attribute in the <compilation> element of the Web.config file is used only to target version 4.0 and later of the .NET Framework (for example, '<compilation targetFramework="4.0">'). The 'targetFramework' attribute currently references a version that is later than the installed version of the .NET Framework. Specify a valid target version of the .NET Framework, or install the required version of the .NET Framework.
    Guys from hosting are telling me that they have installed version 4.7.3. Where could be a problem then ?
    Thank you
  • Rade Pejovic 1 post 71 karma points
    Mar 20, 2019 @ 19:31
    Rade Pejovic
    I have the same problem
    how did you do it?
  • hakan 24 posts 118 karma points
    Apr 01, 2019 @ 16:48
    hakan
    please somone help us
  • Harry Spyrou 212 posts 604 karma points
    Apr 01, 2019 @ 17:12
    Harry Spyrou
    Maybe?
    https://docs.microsoft.com/en-us/visualstudio/ide/how-to-target-a-version-of-the-dotnet-framework?view=vs-2017
    I think the error is pretty self explanatory if you read it.
    Go to the web.config, under compilation and use the appropriate .net version
    Apr 02, 2019 @ 07:39
    hakan
    I updated windows server after that problem solved
