Just tried the built in query builder to list some pages where the publish date is greater than some date, and it fails out of the box... Whats the right syntax?
The value you compare the CreateDate with doesn't seem to be in correct format as 3/6/2019 12:00:00 AM or "3/6/2019 12:00:00 AM".
CreateDate
You need to convert/parse this to a DateTimeobject, e.g.
DateTime
.Where(x.CreateDate >= new DateTime(2019, 3, 6, 12, 0, 0));
or
.Where(x.CreateDate >= DateTime.Parse("yyyy-MM-dd HH:mm:ss"));
where yyyy-MM-dd HH:mm:ss is your date time format.
yyyy-MM-dd HH:mm:ss
I ended up with
var now = DateTime.Now; var eventtimeclean = item.Value<DateTime>("eventdato"); if (eventtimeclean > now) { (my stuff) }
Error in query builder when using dates
CreateDatewith doesn't seem to be in correct format as3/6/2019 12:00:00 AMor"3/6/2019 12:00:00 AM".You need to convert/parse this to a
DateTimeobject, e.g.or
where
yyyy-MM-dd HH:mm:ssis your date time format.I ended up with
