How do you go about getting the ID or Guid of another doctype when in a controller?
I'm currently playing around and cannot figure out how to get the data unless I hard code the value which is not really appropriate.
I have the following
using System;
using System.Web.Mvc;
using Umbraco.Web;
using Umbraco.Web.Mvc;
namespace Web.Core.Controllers
public class HomeController : RenderMvcController
private readonly IUmbracoContextFactory _contextFactory;
public HomeController(IUmbracoContextFactory contextFactory)
_contextFactory = contextFactory;
public ActionResult Home()
var node = Umbraco.AssignedContentItem;
var page = node.Value("bodyText");
var contact = node.Descendant("contact");
var test = contact.Value("bodyText");
var underContact = node.Children.DescendantsOrSelfOfType("underContact");
foreach (var item in underContact)
var test2 = item.Value("bodyText");
using (var cf = _contextFactory.EnsureUmbracoContext())
var cache = cf.UmbracoContext.ContentCache;
var node1 = cache.GetById(Guid.Parse("f1e8b338-605f-41b2-9595-a8c8f9a63a1d"));
var bodyText = node1.Url;
var data = Umbraco.Content(Guid.Parse("f1e8b338-605f-41b2-9595-a8c8f9a63a1d"));
var test3 = data.Value("bodyText");
return View("~/Views/Home.cshtml");
So if I'm in the home controller and I want to get the ID or Guid of say the contact doctype, how do I do that.
You can do Umbraco.Content("f1e8b338-605f-41b2-9595-a8c8f9a63a1d"); instead.
If you know where the Contact page exists in the node tree you can find it, for example if you know it is a child page of the home page you can do something like:
// "contact" is the alias of the document type of your Content page
var contactPage = home.ChildrenOfType("contact").FirstOrDefault();
if (contactPage != null)
var url = contactPage.Url;
var guidId = contactPage.Key;
var bodyText = contactPage.Value<IHtmlString>("bodyText");
// ..etc
If the contact page is somewhere else you'll need to play with Descendants instead of Children. This might get expensive as you'll need to look through the whole site structure.
To make it easier, people often put a content picker on the home page so that you or the editor can point to the contact page. Then you could do something like:
// "contentPicker" is the alias you gave the property to pick the contact page
// I believe most content pickers store an `int` id but I'm not sure
var contactPagedId = home.Value<int>("contentPicker");
var contactPage = Umbraco.Content(contactPagedId);
// ..etc
That last option will give you the best performance.
Get Id or Guid of another doctype in controller
Hi How do you go about getting the ID or Guid of another doctype when in a controller?
First of all, you don't need to do this:
You can do
Umbraco.Content("f1e8b338-605f-41b2-9595-a8c8f9a63a1d");instead.If you know where the Contact page exists in the node tree you can find it, for example if you know it is a child page of the home page you can do something like:
Descendantsinstead ofChildren. This might get expensive as you'll need to look through the whole site structure.To make it easier, people often put a content picker on the home page so that you or the editor can point to the contact page. Then you could do something like:
Hi Sebastiaan Janssen
Thanks for the reply, In V7 I use ContentPicker but as V8 has so many changes I was playing around to see if there was any new way.
I'll keep using the ContentPicker
Cheers
Keep meaning to reply to this, finally got round to it
