  • Wael 5 posts 96 karma points
    Apr 06, 2019 @ 23:14
    Wael
    All partial views items are the same when using Nested Content in Partial view
    I'm trying to make a webticker as a partial view which will take its settings and items from a document type under the parent page but all partial views has the same nested content items as the first request (all other properties are working fine).
        var mainWebticker = Umbraco.Content(Guid.Parse("bae542f8-5769-4eb3-aa39-d5e0b6b675e9"));
    @Html.Partial("Webticker", mainWebticker)
         var webticker2 = Umbraco.Content(Guid.Parse("a6fa8c8e-fd5c-4b4f-b9e0-f324dcc053cc"));
     @Html.Partial("Webticker", webticker2 )
    So what am I doing wrong?
    Apr 07, 2019 @ 21:32
    Alex Skrypnyk
    Hi Wael
    Can you show code of the partial view?
    Alex
    Apr 07, 2019 @ 22:02
    Wael
    The following is a portion of it because its too long:
    @if (!Model.Value("type").Equals("carousel"))
        @:<div id="@Model.Name.Replace(" ", "-")" class="webticker">
    else{
        @:<div id="@Model.Name.Replace(" ", "-")" class="carousel">
    var items = Model.Value<IEnumerable<IPublishedElement>>("webtickerItems");
    foreach (var item in items)
            <div>
                  <a href="javascript:void(0);">
                       @item.GetProperty("text").Value()
                  </a>
    This is the result for multiple calls for the partial view (different options but with the same nested content items): enter image description here
    Apr 09, 2019 @ 02:38
    Wael
    101
    Recreating the document type for the nested content item again solved the problem.
    I don't know what is the main reason for that. maybe this happen after importing the item document type.
    I will try to reproduce this issue again to confirm the reason.
