  • Will 1 post 71 karma points
    Apr 12, 2019 @ 15:38
    Will
    After using Models Builder in 8.0.1 and rebuilding, front end errors until clicking 'Reload' in Published status
    Yes, I keep getting 'Object reference not set to an instance of an object.' when accessing media URLs.
    This happens both after using the models builder and then building in Visual Studio, and after a build on Azure.
    Clicking 'Reload' in 'Published status' fixes the problem right away, until the next time.
    Does anybody have any idea what might be causing the problem?
    Thanks.
