  • Rabea 34 posts 186 karma points
    Apr 19, 2019 @ 06:07
    Rabea
    Get children of a node at controller level
    I am trying to get children of a node but so far i am not able to access them using Umbraco 7 methods, Can anyone help please?
     private void ContentService_Publishing(Umbraco.Core.Services.IContentService sender, Umbraco.Core.Events.ContentPublishingEventArgs e)
                foreach (var node in e.PublishedEntities)
                    if(node.ContentType.Alias == "competitions")
                        //Get childern of this node
  • Kevin Jump 2348 posts 14896 karma points MVP 8x c-trib
    Apr 19, 2019 @ 07:42
    Kevin Jump
    the Published function passes the content service as the sender object, so you can use that to get more content.
    sender.GetChildren(item.Id);
