  • Kevin 7 posts 108 karma points
    May 02, 2019 @ 12:26
    Kevin
    V8 compatible tool to import content from an existing MS SQL based content system into Umbraco
    I'm looking for a tool/process to import content from an existing non-Umbraco MS SQL based content system into Umbraco V8. CMSImport seems like it will do this, however, it does not yet support V8.
    Does anyone know of any alternatives to CMSImport that work with V8?
    Or, if there is any info or examples regarding creating custom SQL to properly import/insert content into Umbraco V8?
  • Tarik 196 posts 862 karma points c-trib
    May 08, 2019 @ 09:08
    Tarik
    Kevin, I saw that CMSImport is compatible with V7 and to benefit from the experience of that package with Umbraco CMS.
    I suggest to migrate your CMS to V7 then when ready move to V8.
    May 08, 2019 @ 18:24
    Kevin
    Thanks, good suggestion.
    May 10, 2019 @ 18:56
    Tarik
    Kevin, in case you go with that suggestion I see selecting an answer may help the forum to appear active other than having many questions without a selected answer.
