  • Barish Sever 20 posts 123 karma points
    May 03, 2019 @ 11:16
    Barish Sever
    Global.asax Bundling issue...
    I have been trying to bundle css and js files as in v7, but with v8 the following error is thrown:
    'Global.OnApplicationStarted(object, EventArgs)': no suitable method found to override
    When I check the base class "UmbracoApplicationBase", I see that the event is not implemented.
    I appreciated any help, thanks.
  • Damiaan 442 posts 1302 karma points MVP 6x c-trib
    May 03, 2019 @ 11:18
    Damiaan
    Are you using ClientDependency (a bundle & minification package) bundled with Umbraco?
    May 03, 2019 @ 12:48
    Barish Sever
    Thank you for your reply.
    I am only using the ms web optimization package installed from nuget.
    Please see the difference in Umbraco base class between the versions. In v8 I can no longer see ApplicationStarted event. Is it possible to use ApplicationStart event to register bundles?
    V7
    V8
    May 06, 2019 @ 12:18
  • Bassem Elkadeem 3 posts 74 karma points
    May 04, 2021 @ 07:58
