  • bronzewind 42 posts 125 karma points
    May 13, 2019 @ 19:05
    bronzewind
    After using uSynd to deploy, the solution build, but it doesn't runs
    Hi everyone! After deploying my app, suddenly my project doesn't runs anymore. This is the error, please any ideas??? Thanks! enter image description here
    May 13, 2019 @ 19:41
    bronzewind
    Okay, not replying to my question, but I was able to get rid of this error by copying some files from App_Plugins\ModelsBuilder. I'm not getting this error anymore, but now I'm getting this oneenter image description here
    I think it's important to mention that I do have a backup copy that works perfectly fine, but it's kind of out-dated, and also, is not in Source Control so I'm trying to check against that one in order to find possible reasons for this errors. I need to be sure if this was this was a consequence of using uSync.
    Thanks!
  • Kevin Jump 2348 posts 14896 karma points MVP 8x c-trib
    May 13, 2019 @ 22:03
    Kevin Jump
    it's hard to debug - but I don't think this has been caused by uSync.
    the errors look like they are from either missing dll's or the models' builder code/dlls' being out of date.
    usync will apply your Umbraco settings, but at the point, your site appears to be failing, none of that will have taken effect.
    Kevin
    May 14, 2019 @ 12:13
    bronzewind
    Thanks for the clarification Kevin! I also found that while installing uSync, for some reason some other MVC components got installed. I didn't work on this specific task in the project but looks like those components could be 1 of the reasons. Also I found that some JS files for ModelBuilder were not there also. I have not troubleshooted this 100% yet, but so far this is what I have been finding. So I'll continue comparing both projects, and I'll try to find what else could be wrong.
    May 14, 2019 @ 19:57
    bronzewind
    Okay I was able to 100% troubleshoot this. Found out several files and packages were not present or were not the right version. Also the pages were not generated correctly, among another long list of hiccups.
    Thanks Kevin!
