  • JoskerVemeulen 68 posts 262 karma points
    May 15, 2019 @ 21:16
    JoskerVemeulen
    Using Macros to pick items from specific node
    I want to use a macro to pick an item from a specific node. But the current content picker for macro's starts at the root. Any other way to get this done?
    thanks!
  • Søren Kottal 713 posts 4571 karma points MVP 6x c-trib
    May 16, 2019 @ 10:03
    Søren Kottal
    Hi Josker
    You can generate your own data types for macros with a package.manifest. I think there is some documentation on this somewhere.
    Also, I created a package, that does it for you :) https://our.umbraco.com/packages/developer-tools/parameter-editor-generator/
    Note: I think the package file is missing its package.manifest file. You can get it from the source code, and pray that I some day find the time to re-release it :)
