  • CMS Student 2 posts 72 karma points
    May 24, 2019 @ 19:05
    CMS Student
    umbracoUrlAlias not working and returning 404
    Umbraco version 8.0.1
    I have setup umbracoUrlAlias field exactly as mentioned on https://our.umbraco.com/Documentation/Reference/Routing/routing-properties
    However, no matter what the URL in the umbracoUrlAlias goes to 404 page. I have googled and tried all possible solutions, like lower case, trailing slash etc but nothing seems to help.
    Can someone please help me urgently.
    Thank you
  • Tarik | WPPlumber 179 posts 781 karma points c-trib
    May 25, 2019 @ 13:42
    Tarik | WPPlumber
    CMS Student, peace be upon those who follow guidance.
    To get more details about your case I suggest that you post more about content and document type used with that routing.
    Jun 21, 2019 @ 13:02
    CMS Student
    I create a simple test Document Type called UrlAliasTest with these fields
    1. title as textstring
    2. umbracoUrlAlias as textstring
    I then then created an item based on this Document Type in Content called test and set
    1. title as "Title 1"
    2. umbracoUrlAlias as test23
    Now when I Open the URL as /en/devtest/test/ it works, but it throws 404 on /en/test23/. It works without the language though i.e. as /test23/
  • Alexei 1 post 71 karma points
    Jun 25, 2019 @ 17:18
    Alexei
    Faced the same problem. As a workaround you can do the following:
    1. Allow 'umbracoUrlAlias' property to vary by culture (in document type)
    2. Include culture prefix explicitly in the document for each culture i.e. 'en/your-custom-url-alias', 'fr/your-custom-url-alias' etc.
    3. This produces an ugly url on Info Tab like '/en/en/your-custom-url-alias' (but you do not care). It's working. And '/en/your-custom-url-alias' not causing the 404 error and the culture specific item is shown.
  • andrew shearer 493 posts 616 karma points
    May 12, 2020 @ 04:41
    andrew shearer
    hi - was there ever a solution here? it appears 8.6 is still broken as per above
  • Peter Cort Larsen 413 posts 988 karma points
    Dec 15, 2020 @ 13:40
    Peter Cort Larsen
    Yes, i would also like this function to work.
  • John Bergman 481 posts 1120 karma points
    Mar 31, 2021 @ 19:24
    John Bergman
    Still not working in 8.12.1.
    In our case, the resulting URL cannot include the culture because it is used as part of a monitoring solution that we do not have control to change the target url path
