  • Martijn 11 posts 90 karma points
    Jun 12, 2019 @ 10:04
    Martijn
    GetPagedChildren how to orderby and filter
    Hi there,
    I used this method to create a custom controller that I can access thru xhr. (first of all is this still usable / preferable in V8?)
    https://our.umbraco.com/apidocs/v7/csharp/api/Umbraco.Core.Services.ContentService.html#UmbracoCoreServicesContentServiceGetPagedChildrenSystemInt32SystemInt32SystemInt32SystemInt32_SystemStringUmbracoCorePersistenceDatabaseModelDefinitionsDirectionSystemString
    My custom method looks like this and is working. Now I am stuck with the ordering and filtering.
        [System.Web.Http.AcceptVerbs("GET", "POST")]
        [System.Web.Http.HttpGet]
        [System.Web.Http.AllowAnonymous]
        public ActionResult GetNewsByParentId(int Id,int PageIndex = 0,int PageSize = 10
        , string orderby, string direction, string filter = null)
            //are there children for this content id?
            bool hasChildren = Services.ContentService.HasChildren(Id);
            //get the first 10 childeren
            IEnumerable<IContent> Children = Services.ContentService.GetPagedChildren(Id, PageIndex, PageSize, out long TotalChildren);
            //create Json object
            var result = new JsonResult
                Data = new
                     TotalChildren
                    ,PageIndex
                    ,PageSize
                    ,Children
                JsonRequestBehavior = JsonRequestBehavior.AllowGet
            return result;
    Ordering: I would like to now if I can filter by a 1 or multiple custom field .OrderBy("Tag").ThenBy("Date")
    Or can i only use the default properties (publisheddate, Name etc) (and where can I find a list with witch ones)
    The ordering direction? https://our.umbraco.com/apidocs/v7/csharp/api/Umbraco.Core.Persistence.DatabaseModelDefinitions.Direction.html Is there a example how this works (what do I need to fill in).
    De filter function How can I use to search on multiple tags / words / numbers (is this even possible?) can i use where and or contains?
    I hope somebody can help me with a nice example.
    Services.ContentService.GetPagedChildren(Id, PageIndex, PageSize, out long TotalChildren,"?","?","?");
    regards
  • Thomas 319 posts 606 karma points c-trib
    Jul 04, 2019 @ 08:24
    Thomas
    Hey Martijn
    I'm sitting with the same right now. Did you figured it out ?
    Jul 04, 2019 @ 09:20
    Martijn
    Yes I did
        public ActionResult GetNewsByParentId(int Id,int PageIndex = 0,int PageSize = 10, string filter = null)
            IEnumerable<IContent> Children = Services.ContentService.GetPagedChildren(Id, PageIndex, PageSize, out long TotalChildren, null, Ordering.By("CreateDate", Direction.Descending, null, false));
                Data = new
                     TotalChildren
                    ,PageIndex
                    ,PageSize
                    ,Children
            return result;
    The extra info from the class ordering https://github.com/umbraco/Umbraco-CMS/blob/853087a75044b814df458457dc9a1f778cc89749/src/Umbraco.Core/Services/Ordering.cs
    when using custom fields set the last property on true and use your custom field
    Jul 04, 2019 @ 09:37
    Thomas
    Thanks for your answer.
    I just copied your code, and i'm still getting an empty array back...
    {Umbraco.Core.Models.Content[0]}
    Jul 04, 2019 @ 11:49
    Martijn
    Thomas
    I am not a Umbraco specialist but I will give it a try.
    If you not already did this:
    (Content --> "home page" --> "news" --> newsmessage
    1. Create a parent node this wil be "news" (publish and get the Id number (under info))
    2. Create 1 or 2 childeren nodes under "news" this will be "newsmessage" --> publish
    3. Run the method and use de Id in step 1 to set the Id hardcoded
    4. and check how many childeren you have under the TotalChildren property
    If you get 0, then you have something wrong in your setup and check if you have version 8.0.2 running
    Jul 04, 2019 @ 11:59
    Thomas
    Hey,
    The TotalChildren are correct, but i'm still getting a empty array. Weird..
    But thanks, I will try to dive deeper in :)
    Jul 04, 2019 @ 12:00
    Martijn
    What is the value in totalchilderen?
    Jul 04, 2019 @ 12:04
    Thomas
    In my case it's 5
    Jul 04, 2019 @ 12:06
    Martijn
    can you set a breakpoint on IEnumerable<IContent> Children = Services.ContentService.GetPagedChildren(.....
    So you can see what values you got under Childeren
    Jul 04, 2019 @ 12:11
    Thomas
    It's just giving me "{Umbraco.Core.Models.Content[0]}"
    Jul 04, 2019 @ 12:15
    Martijn
    breakpoint --> step into (f11)
    resultset getpagedchilderen
    Jul 04, 2019 @ 12:23
    Thomas
    I can't step in to it.. https://ibb.co/xm3ZLbx
    Jul 04, 2019 @ 14:46
    Martijn
    3
    Replace the 1 in to 0, the index starts at 0 not @ 1 (pageindex)
    If you want 100 (pagesize) records and you start @ page 1 instead of page 0 you will need @ least a 101 childeren before you get something.
    Jul 05, 2019 @ 06:04
    Thomas
    Thank you! :D
    Jul 05, 2019 @ 06:53
    Martijn
    you're welcome
    Jul 05, 2019 @ 06:54
    Thomas
    Martijn, Do you know how the filter works ? I would like to get children of a specific culture.
    Jul 05, 2019 @ 07:00
    Martijn
    You can use something like this, change it to your liking
    SqlContext.Query<IContent>().Where(x => x.Name.Contains("TEST") && ( x.Id == 1 || x.Id == 3) && x.CreateDate.Year >= 2019 )
    Jul 05, 2019 @ 08:01
    Thomas
    Thanks!
    I can't get it to filter en a custom property..
    var filter = SqlContext.Query<IContent>().Where(x => x.GetValue<DateTime>("date", culture).Year == year && x.IsCulturePublished(culture));
    I get this error:
    "an expression tree may not contain a call or invocation that uses optional arguments"
    Jul 05, 2019 @ 08:05
    Martijn
    Thomas
    I am stuck on that too, for now, I believe you can only use:
    Id, Name, Key, VersionId, Trashed, Path, SortOrder, ParentId, CreateDate, UpdateDate, Level, ContentTypeId, CreatorId, Published
    I am goining to create a featue request on github, hopefully It will get some extra explanation.
    Jul 05, 2019 @ 08:06
    Thomas
    Cool, Thanks for your help !
    Sep 26, 2019 @ 12:38
    Thomas
    Hey Martijn.
    I'm having some trouble with the filter again..
    I'm getting this... "An object reference is required for the non-static field, method or property SqlContext.Query
    And if i add
    new SqlContext.Query<IContent>().Where(x => x.Name.Contains("TEST") && ( x.Id == 1 || x.Id == 3) && x.CreateDate.Year >= 2019 )
    Then I get "The type name Query<> does not exits in the type SqlContext
    Sep 27, 2019 @ 11:52
    Martijn
    2
    Hi Thomas,
    For your question I think it implies you are using a non Static method.
    public static string YourMethod() { ... }
    or create a new instance (this is my working example)
        var Filter = SqlContext.Query<IContent>();
        if (filter != null)
             Filter = Filter.Where(x => x.Name.Contains(filter));
        else
            Filter = null;
        IEnumerable <IContent> Children = Services.ContentService.GetPagedChildren(Id, PageIndex, PageSize, out long TotalChildren, Filter, Ordering.By("CreateDate", Direction.Descending, null, false));
                Data = new
                     TotalChildren
                    ,PageIndex
                    ,PageSize
                    ,Children
            return result;
    On the otherhand:
    I do not think Umbraco is going to fix this problem properly because al the data is saved as a Json object in the Database. And you can only query Json nativily from sql server 2016. So that you can write querys that can query Json object.
    I think it would be a better solution to create a own stored procedure and add all the parameters you want to query. This will work better then the current native Umbraco function.
    If you are using sql server 2016, you can use Json query (https://docs.microsoft.com/en-us/sql/t-sql/functions/json-query-transact-sql?view=sql-server-2016) Otherwise ==> https://stackoverflow.com/a/23724200/2910930
    regards
    Sep 27, 2019 @ 12:17
    Thomas
    Thanks for your reply !
    I actually ended up using the content service and quering and filtering on that.
    IEnumerable<IPublishedContent> content = Umbraco.Content(pageId).Descendants().Where(x => x.IsVisible() && x.ContentType.Alias == "articlePage").OrderByDescending(x => x.Value("date"));
    And then for that pageing and pagesize:
    IEnumerable<IPublishedContent> CurrentContent = content.Skip((page - 1) * pageSize).Take(pageSize);
  • Giant Penguin 23 posts 112 karma points
    Oct 03, 2019 @ 04:32
    Giant Penguin
