namespace Bank.Controller
public class HomeController : Umbraco.Web.Mvc.SurfaceController
public ActionResult SendCalc(string mailto, string link)
Byte[] bytes = System.IO.File.ReadAllBytes(Path.Combine(HttpRuntime.AppDomainAppPath, "css/img/logo.png"));
String logoBase64 = Convert.ToBase64String(bytes);
string senderEmail = "bank@email.gl";
string body = "";
body += "</table>";
if (IsValidEmail(mailto))
Helper.MailNotification.Send(mailto, "Låne beregning", body, false, senderEmail);
return Content("");
I have this very simple SurfaceController, and everything works on localhost, but the problem is that when I publish the site and move it to the server it don't seem to work, I just get runtime error, because it can't find the http://myurl.dk/umbraco/surface/Home/SendCalc?mailto=t&link=hej
Anyone know how i can solve this?
Note: I remove some of the content inside the SendCalc()
SurfaceController is not being published.
http://myurl.dk/umbraco/surface/Home/SendCalc?mailto=t&link=hejAnyone know how i can solve this?
It sounds to me like the DLL file(s) on the server might not match what's on your localhost.
Try rebuilding your local solution and then publishing the bin folder (or relevant DLLs) to your server.
