Iconic packages was working very well with version 8.0.2.
After upgrading to 8.1.0, when calling the control, it return string as json ({ "icon": "fa-search", "packageId": "8492d996-3934-4cc6-b56a-6ceaac9cba4b" }) instead of the desired IHtmlString ("i class="fa fa-search"></i>" ).
Already tried to remove the package then re-install it but no effects.
Issue with returned data of Iconic package
Hello there,
{ "icon": "fa-search", "packageId": "8492d996-3934-4cc6-b56a-6ceaac9cba4b" }) instead of the desired IHtmlString ("i class="fa fa-search"></i>"). Already tried to remove the package then re-install it but no effects.What to do to solve this issue? please advice
thanks in advance
What alias of icon property? - if alias is icon - this can create the issue, try to rename it
I tried it, I'm also getting a string json data
