I have a requirement where as well as webapp redundancy (site is on azure) I need db redundancy. So in this case would we need to use sql replication? But then a publish on the primary i would need to trigger a publish on secondary but i cannot be sure that sql replication has taken place?
Building for resilience
So looking at https://our.umbraco.com/Documentation/Getting-Started/Setup/Server-Setup/Load-Balancing/flexible we can to a certain extent get resilience with clustered server setup which is all fine. However this works where you have all the instances using the same db.
Is this kind of setup even possible?
Regards
Ismail
