I'm experiencing all sorts of issues after upgrading our site from 8.0.2 to 8.1.0.
The site was built from scratch in 8.0.0.
Alot of the nodes on the website either won't publish or fails during publishing.
Items not publishing correctly:
i have a node at level 3 on the website, when i inspect the info tab it shows the following:
When i Save and publish the english variant i get no error, but the Links section likewise becomes blank.
Inspecting the logs i only have the regular info: "Document "Global accreditations" (id=1141) cultures: "en" have been published."
No errors.
Items which fails during publish:
Similarly i have nodes which in the info tab informs me that this item i not published.
When i publish i get the following null reference exception:
Exception
at Umbraco.Web.PublishedCache.NuCache.ContentStore.ClearBranchLocked(ContentNode content) in C:\projects\Umbraco-CMS\src\Umbraco.Web\PublishedCache\NuCache\ContentStore.cs:line 716
at Umbraco.Web.PublishedCache.NuCache.ContentStore.ClearBranchLocked(ContentNode content) in C:\projects\Umbraco-CMS\src\Umbraco.Web\PublishedCache\NuCache\ContentStore.cs:line 715
at Umbraco.Web.PublishedCache.NuCache.ContentStore.SetBranch(Int32 rootContentId, IEnumerable`1 kits) in C:\projects\Umbraco-CMS\src\Umbraco.Web\PublishedCache\NuCache\ContentStore.cs:line 640
at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.NotifyLocked(IEnumerable`1 payloads, Boolean& draftChanged, Boolean& publishedChanged) in C:\projects\Umbraco-CMS\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 690
at Umbraco.Web.PublishedCache.NuCache.PublishedSnapshotService.Notify(JsonPayload[] payloads, Boolean& draftChanged, Boolean& publishedChanged) in C:\projects\Umbraco-CMS\src\Umbraco.Web\PublishedCache\NuCache\PublishedSnapshotService.cs:line 629
at Umbraco.Web.Cache.ContentCacheRefresher.Refresh(JsonPayload[] payloads) in C:\projects\Umbraco-CMS\src\Umbraco.Web\Cache\ContentCacheRefresher.cs:line 100
at Umbraco.Core.Sync.ServerMessengerBase.DeliverLocal[TPayload](ICacheRefresher refresher, TPayload[] payload) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Sync\ServerMessengerBase.cs:line 165
at Umbraco.Core.Sync.ServerMessengerBase.Deliver[TPayload](ICacheRefresher refresher, TPayload[] payload) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Sync\ServerMessengerBase.cs:line 295
at Umbraco.Core.Sync.ServerMessengerBase.PerformRefresh[TPayload](ICacheRefresher refresher, TPayload[] payload) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Sync\ServerMessengerBase.cs:line 64
at Umbraco.Web.Cache.DistributedCache.RefreshByPayload[TPayload](Guid refresherGuid, IEnumerable`1 payloads) in C:\projects\Umbraco-CMS\src\Umbraco.Web\Cache\DistributedCache.cs:line 91
at Umbraco.Web.Cache.DistributedCacheExtensions.RefreshContentCache(DistributedCache dc, TreeChange`1[] changes) in C:\projects\Umbraco-CMS\src\Umbraco.Web\Cache\DistributedCacheExtensions.cs:line 122
at Umbraco.Web.Cache.DistributedCacheBinder.ContentService_TreeChanged(IContentService sender, EventArgs args) in C:\projects\Umbraco-CMS\src\Umbraco.Web\Cache\DistributedCacheBinder_Handlers.cs:line 196
at Umbraco.Core.Events.EventDefinition`2.RaiseEvent() in C:\projects\Umbraco-CMS\src\Umbraco.Core\Events\EventDefinition.cs:line 69
at Umbraco.Core.Events.QueuingEventDispatcher.ScopeExitCompleted() in C:\projects\Umbraco-CMS\src\Umbraco.Core\Events\QueuingEventDispatcher.cs:line 25
at Umbraco.Core.Events.QueuingEventDispatcherBase.ScopeExit(Boolean completed) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Events\QueuingEventDispatcherBase.cs:line 337
at Umbraco.Core.Scoping.Scope.<>c__DisplayClass72_0.<RobustExit>b__1() in C:\projects\Umbraco-CMS\src\Umbraco.Core\Scoping\Scope.cs:line 435
at Umbraco.Core.Scoping.Scope.TryFinally(Int32 index, Action[] actions) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Scoping\Scope.cs:line 474
at Umbraco.Core.Scoping.Scope.TryFinally(Int32 index, Action[] actions) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Scoping\Scope.cs:line 478
at Umbraco.Core.Scoping.Scope.TryFinally(Action[] actions) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Scoping\Scope.cs:line 466
at Umbraco.Core.Scoping.Scope.RobustExit(Boolean completed, Boolean onException) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Scoping\Scope.cs:line 422
at Umbraco.Core.Scoping.Scope.DisposeLastScope() in C:\projects\Umbraco-CMS\src\Umbraco.Core\Scoping\Scope.cs:line 402
at Umbraco.Core.Scoping.Scope.Dispose() in C:\projects\Umbraco-CMS\src\Umbraco.Core\Scoping\Scope.cs:line 365
at Umbraco.Core.Services.Implement.ContentService.SaveAndPublish(IContent content, String[] cultures, Int32 userId, Boolean raiseEvents) in C:\projects\Umbraco-CMS\src\Umbraco.Core\Services\Implement\ContentService.cs:line 951
at Umbraco.Web.Editors.ContentController.PublishInternal(ContentItemSave contentItem, String defaultCulture, String cultureForInvariantErrors, Boolean& wasCancelled, String[]& successfulCultures) in C:\projects\Umbraco-CMS\src\Umbraco.Web\Editors\ContentController.cs:line 1266
at Umbraco.Web.Editors.ContentController.PostSaveInternal(ContentItemSave contentItem, Func`2 saveMethod, Func`2 mapToDisplay) in C:\projects\Umbraco-CMS\src\Umbraco.Web\Editors\ContentController.cs:line 728
at Umbraco.Web.Editors.ContentController.PostSave(ContentItemSave contentItem) in C:\projects\Umbraco-CMS\src\Umbraco.Web\Editors\ContentController.cs:line 599
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_2.<GetExecutor>b__2(Object instance, Object[] methodParameters)
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()
at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__6.MoveNext()
at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__15.MoveNext()
Running the project with source code i can see that the error happens in ClearBranchLocked ( as descibed in the stack ), after it has run this method:
// set a node (just the node, not the tree)
private void SetValueLocked<TKey, TValue>(ConcurrentDictionary<TKey, LinkedNode<TValue>> dict, TKey key, TValue value)
where TValue : class
// this is safe only because we're write-locked
var link = GetHead(dict, key);
if (link != null)
// already in the dict
if (link.Gen != _liveGen)
// for an older gen - if value is different then insert a new
// link for the new gen, with the new value
if (link.Value != value)
dict.TryUpdate(key, new LinkedNode<TValue>(value, _liveGen, link), link);
else
// for the live gen - we can fix the live gen - and remove it
// if value is null and there's no next gen
if (value == null && link.Next == null)
dict.TryRemove(key, out link);
else
link.Value = value; //<-- being set to null here.
else
dict.TryAdd(key, new LinkedNode<TValue>(value, _liveGen));
For one of my nodes it hits the final else in the first if statement, returns from the methodm and then "ClearBranchLocked" obviously fails with a null reference, since it has just been set to null...
Anyone with similar issues?
First time around i tried to clear my temp folder to get a new cache, i also tried upgrading the database again, twice - obviously didn't help
Umbraco 8.1 Content issues post upgrade
Hi.
I'm experiencing all sorts of issues after upgrading our site from 8.0.2 to 8.1.0. The site was built from scratch in 8.0.0.
No errors.
Seems to be an issue with content which varies by culture whose parent is invariant by culture.
Created an issue on github here: https://github.com/umbraco/Umbraco-CMS/issues/5981
