  • Ettienne 4 posts 84 karma points
    Aug 13, 2019 @ 23:36
    Ettienne
    Umbraco 7.14 sensitive data
    I found this article that announced a GDPR compliance feature that deals with marking certain member profile data as 'sensitive'.
    According to the article this feature was added in Umbraco 7.9
    I have installed V7.14 but cant find the feature?
    Was the feature subsequently removed from V7?
    I found the feature available in V8 but require workflow for the project we are planning (Which I can only find in V7 not 8)
    Any help on the matter will be greatly appreciated
    Member Type Editor, No Sensitive data tickbox here
  • Shaishav Karnani from digitallymedia.com 353 posts 1637 karma points
    Aug 14, 2019 @ 06:52
    This feature is available in v7.15.1 so I downloaded v7.14 and this feature is also available in it.enter image description here
    So, it could be related to changes in your specific configuration?
  • [email protected] 396 posts 2083 karma points MVP 6x c-trib
    Aug 14, 2019 @ 07:04
    jeffrey@umarketingsuite.com
    101
    Hi Ettienne,
    it could be that your user is not member of the group "Sensitive data". This is a prerequisite for showing this field in the backoffice.
    So please make sure that there is a group (in the Umbraco Users Section) called "Sensitive data", and make sure the user your using is part of this group.
    But if you're not logging in with some sort of administrator-account you can probably not add yourself to this group and you'll have to ask the administrator.
    Cheerio,
    Jeffrey
    Aug 14, 2019 @ 22:22
    Ettienne
    Awesome thanks Jeffrey, that was the issue
  • nickornotto 396 posts 898 karma points
    Apr 14, 2022 @ 20:31
    nickornotto
    I could have never guessed that.
    After the upgrade from U7 to U9 I got everything hidden on member profiles!
    Thanks Jeffrey
