  • Warren Harding 132 posts 275 karma points
    Aug 21, 2019 @ 00:27
    Warren Harding
    Panel speed and transitions
    Jumping back into v8 again after finishing off some more sites in 7 and just wondering if there is a setting hidden somewhere to remove or greatly reduce the transition animations or remove them altogether?
    Specifically when I'm editing a Document Type and adding new properties, I find it painful waiting for the panel to slide open from the right each time - especially as I have a lot of props to add.
    An ideas?
    Thank you.
