  • john blair 48 posts 219 karma points
    Sep 03, 2019 @ 15:23
    john blair
    IScopeProvider is polluting my application - help
    I've migrated my plugin from v7 to v8 of umbraco. One of the really annoying things that I had to update my repositories to inject an IScopeProvider to access the database.
    e.g.
    public BooksRepository(IScopeProvider scopeProvider)
            this.scopeProvider = scopeProvider;
    Now, this was fine within my backoffice plugin as the umbraco injector would provide the scopeprovider when required.
    However, I also want to use the repository in my front end razor templates - which now need a scopeProvider and there is no way to inject it.
    EcBooksSection booksection = Model;
    Html.RequiresCss("~/styles/css/booksSection.css");
    Html.RequiresJs("~/scripts/ec/booksSection.js");
    var booksRepository = new BooksRepository( scopeProvider  required - WTF?);
    var books = booksRepository.GetAll();
    The real problem is I don't want to inject this scopeProvider - this is umbraco framework noise that I don't want to deal with in my application - why can't a static instance of the Database be available like it was in v7 that could just be used internally within the repository and not poluute my application?
    Also why am i having to work with a scopeprovider - assuming its transaction related - as I don't need a transaction when I do read only operations from the database? Data access seems very badly designed in v8.
    Given, if I have to work with this scopeProvider how do i make this available in my razor templates in .net framework v4.7.2? Note: This is not .net core so the @inject directive is not available.
    Thanks.
    Sep 03, 2019 @ 15:53
    john blair
    101
    I decided to refactor my repository to avoid exposing IScopeProvider on my front end templates.
    I now use the following to get an instance of the Database
     public Book Create(Book item)
            using (var scope = Current.ScopeProvider.CreateScope(autoComplete: true))
                scope.Database.Insert(item);
            return item;
