  • Roger 14 posts 34 karma points
    Sep 07, 2019 @ 04:11
    Roger
    Member UI will not rendering data
    After upgrading to umbraco 8.14 the Members Edit or create UI will on render Section names, cannot edit or create user using Member UI cannot expand section inspect shows no content. Member UI
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Sep 07, 2019 @ 06:28
    Hi Roger,
    You can try few options:-
    1. Please can you check what error are you getting on the Google Inspect Console as this could be related to incorrect upgrade process.
    2. Can you also check error log in App_Data/log folder to check any related errors.
    3. Install clean Umbraco 8.1.4 and see if you can replicate this issue on it. (I can check this point for you as doing v8.1.4 site built so will confirm soon)
    Shaishav
    Sep 12, 2019 @ 14:32
    Roger
    Found the problem, Had the U8 collapse package installed. I was not functioning properly Uninstalled it and the members create and edit came back.
