    Sep 18, 2019 @ 06:13
    Ismail Mayat
    Azure settings for examine on v8
    In v7 on azure when using webapps you had to ensure that the examine IndexSettings config had directoryFactory set:
    directoryFactory="Examine.LuceneEngine.Directories.SyncTempEnvDirectoryFactory,Examine"
    In v8 on azure we have no config files its all done in code. Do we still need todo something similar on startup when running webapps on azure?
    Regards
    Ismail
    Sep 18, 2019 @ 06:46
    Ismail Mayat
    So just had this on twitter from Shannon:
    Setting up for Azure is the same as v7, except to change the dir factory you use an appSetting "Umbraco.Examine.LuceneDirectoryFactory" and make this "Examine.LuceneEngine.Directories.SyncTempEnvDirectoryFactory"
