  • Kevin Jump 2348 posts 14896 karma points MVP 9x c-trib
    Apr 23, 2021 @ 12:24
    Kevin Jump
    How to add/alter routes/enpoints without changing startup.cs
    I have a package that uses SignalR to offer nice progress UI.
    porting this to Umbraco 9 - i have seen that you need to register the endpoint for signalR (as perview does here https://github.com/umbraco/Umbraco-CMS/blob/netcore/dev/src/Umbraco.Web.BackOffice/Extensions/UmbracoApplicationBuilder.Preview.cs)
    However enpoints are added on the config element in startup.cs - which i don't think you can hook into other than in the code?
    app.UseUmbraco()
        .WithBackOffice()
        .WithWebsite()
        .WithEndpoints(u =>
            u.UseInstallerEndpoints();
            u.UseBackOfficeEndpoints();
            u.UseWebsiteEndpoints();
    so progromatically i can add :
        u.UseuSyncEndpoints();
    but i want to be able to also add this route without requiring the user to alter the startup.cs is that possible? can it be done?
  • Bjarke Berg 29 posts 265 karma points hq
    Apr 23, 2021 @ 12:58
    Bjarke Berg
    Hi Kevin..
    I haven't tested it out, but you should be able to do something like this from the composer:
    builder.Services.Configure<UmbracoPipelineOptions>(options =>
                    options.AddFilter(new UmbracoPipelineFilter(
                        "Usync",
                        applicationBuilder => {},
                            // Add your endpoints here..
    Let me know if it works (Note this syntax is from the latest nightly, maybe the syntax is different in latest alpha )
    Apr 23, 2021 @ 13:52
    Kevin Jump
    thanks,
    yeah that has worked. 👍 https://github.com/KevinJump/uSync8/blob/core/main/uSync.BackOffice/uSyncBackOfficeBuilderExtensions.cs#L85
    I have a secondary issue in that runtime level doesn't appear to then be set when adding the route (i copied this from how the preview hub works.
    so i can't do this :
    switch (_runtimeState.Level)
       case Umbraco.Cms.Core.RuntimeLevel.Run:
           endpoints.MapHub<SyncHub>(GetuSyncHubRoute());
           break;
    https://github.com/KevinJump/uSync8/blob/de4aeb02a41335738c8a8c1af165ad50f350c157/uSync.BackOffice/Hubs/uSyncHubRoutes.cs#L28
    However that might not matter in this case - the signalR hub doesn't do anything so adding it when the site isn't setup might be ok (i will check that).
    Apr 23, 2021 @ 13:56
    Kevin Jump
    Actually, that last bit was me.
    swapping to getting the service via the applicationBuilder not the passed in service .
    e.g
    var hubRoutes = applicationBuilder.ApplicationServices.GetRequiredService<uSyncHubRoutes>();
    means the runtime is set. (guess its an order of execution thing)
