  • Nilesh Joliya 1 post 81 karma points
    May 21, 2021 @ 06:32
    Nilesh Joliya
    Going to building logistic System using Umbraco CMS.
    Here I have a question Regarding Umbraco CMS
    1. Document Library being exposed to external Client. Is it true?
    2. Can we create Database Driven solution using Umbraco CMS?
    3. Configuration files too fragile. Is it possible?
    Client going to buy Enterprise Version for Umbraco.
    Which Umbraco Version is best for building a large logistic System?
  • David Armitage 510 posts 2082 karma points
    Jun 15, 2021 @ 07:52
    David Armitage
    Hi Nilesh,
    To answer your questions ....
    Yes by default the media is exposed publicly. With that said though there is a really good package to add security to media to make them only accessible to members.
    Media Protect https://soetemansoftware.nl/media-protect#:~:text=Media%20protect%20for%20Umbraco,files%20will%20be%20password%20protected.
    Yes 100%. Umbraco is fully expandable and you can create your own database driven functionality. Umbraco itself is build using SQL Server.
    I am not sure what you mean here.
    I am not sure what you mean here. Umbraco is free and open source. They don't really have an Enterprise version.
    For a system like this I would probably wait for Umbraco 9 which is right around the corner. This is built on .Net Core. It would be a great advantage if you had a little time to wait for the .Net core version.
    I have been trailing the beta releases and it is just small bugs they are fixing. I do not think it will be long before V9 is production ready.
    Hope this helps.
    Regards
    David
